Page 150 of 205 FirstFirst ... 50100140146147148149150151152153154160200 ... LastLast
Results 1,491 to 1,500 of 2045
    Aug 2013
    #1491
    Quote Originally Posted by mar04 View Post
    Question, kasama ba sa warranty ung sa handbrake? Na experience ko kasi while waiting sa drive thru na inclined (siguro mga 60 degrees) I changed to neutral tapos nag handbrake then umaatras ung unit(naka sagad na taas na ung handbrake pero wala parin). May previous nangyari mga 2yrs ago na nag drive ako ng around 6 km na hindi naka fully disengage ung handbrake. Naamoy lang ng tropa ko then dun ko lang napansin. TIA
    Kung ganyan po ang inclune, minsan di kinakaya ng handbrake lang kung naka Neutral. If automatic, kindly try placing the gear to Park.
    #1492
    Mahirap din ilagay sa "Park" kapag umaatras talaga pede maglock yun parking prawl at di magdisengage yung solenoid ng kambiyo di mo maililipat ng gear. Best practice is to step on the brakes talaga if mga panandaliang tigil lang and gumamit ng kalso kapag matagal na magpapark on an inclined road. Then kapag may time check your rear brakes baka pudpod na kaya ayaw kumagat ng ayos.
    Jun 2012
    #1493
    Quote Originally Posted by dos2 View Post
    gls v 4x2 pala unit. ah so may mga certain incline ang hindi kaya ng handbrake, say kahit brand new ang unit? so its normal?
    Quote Originally Posted by Bin Diesel View Post
    yup, hindi ko rin prina practice na ilagay sa park lalo na at sandaliang hinto lang. so bro kahit brandnew unit may certain angles na hindi kaya ng handbrake?
    Jul 2012
    #1494
    Paadjust nyo ang adjuster rod ng brake shoe cylinder bago eadjust ang slack ng hand brake handle cable, 3 clicks maririnig paghinatak ang handle puede na.
    Aug 2013
    #1495
    Thanks for the info sir.
    So the rule is never use PARK when parking in an incline? Eto po kasi practice ko mapa patag man or inclined parking.
    #1496
    No, you still need to use it kasi di mo naman matatanggal susi kapag di mo nilagay sa Park ang kambiyo. Just make sure na kapit ng todo ang handbrake at wala ng magiging extrang movement bago ilagay sa Park. Sa sobrang incline talaga gumamit ng kalso. It happened to me before akala ko naka lock na ng ayos yung handbrake ko so lagay na sa Park agad yun nung aalis na ako ayaw mag disengage ng solenoid kailangan pa itulak ng konti para makalog at bumitaw yung prawl.
    Well it should lock the tires, except siguro in extreme cases. Never pa ako nakaencounter ng hinatak ko ng ayos ang hand brake at di niya kinaya. Most of the time kapag dumudulas di ko lang naset ng ayos handbrake ko. Kung lagi dumudulas at maayos naman hila mo maybe you need to have the rear brakes checked, baka pudpod na, madumi or need i-adjust yung handbrake.
    Aug 2013
    #1497
    Thanks for sharing. To confirm your statement this is what I found in Wikipedia.
    "Most vehicle manufacturers[3] and auto mechanics[4] do not recommend using the transmission's parking pawl as the sole means of securing a parked vehicle, instead recommending it should only be engaged after first applying the vehicle's parking brake. Constant use of only the parking pawl, especially when parking on a steep incline, means that driveline components, and transmission internals, are kept constantly under stress, and can cause wear and eventual failure of the parking pawl or transmission linkage. The pawl might also fail or break if the vehicle is pushed with sufficient force, if the parking brake is not firmly engaged. Replacement can be an expensive operation since it generally requires removing the transmission from the car.."
    #1498
    Pawl pala yun di prawl. hehe.
    #1499
    bro ROG , adjust natin handbrake mo sa PMS mo. see you
    #1500
    ac fan motor replace
    *ZIX
ISSUES FOR THE MONTERO SPORT. Please post them here.
