Results 1,491 to 1,500 of 2045
May 7th, 2015 10:23 AM #1491
May 7th, 2015 10:37 AM #1492
Mahirap din ilagay sa "Park" kapag umaatras talaga pede maglock yun parking prawl at di magdisengage yung solenoid ng kambiyo di mo maililipat ng gear. Best practice is to step on the brakes talaga if mga panandaliang tigil lang and gumamit ng kalso kapag matagal na magpapark on an inclined road. Then kapag may time check your rear brakes baka pudpod na kaya ayaw kumagat ng ayos.
- Jun 2012
- 269
May 7th, 2015 11:04 AM #1493gls v 4x2 pala unit. ah so may mga certain incline ang hindi kaya ng handbrake, say kahit brand new ang unit? so its normal?
yup, hindi ko rin prina practice na ilagay sa park lalo na at sandaliang hinto lang. so bro kahit brandnew unit may certain angles na hindi kaya ng handbrake?
May 7th, 2015 11:42 AM #1494
Paadjust nyo ang adjuster rod ng brake shoe cylinder bago eadjust ang slack ng hand brake handle cable, 3 clicks maririnig paghinatak ang handle puede na.
May 7th, 2015 12:02 PM #1495
May 7th, 2015 02:21 PM #1496
No, you still need to use it kasi di mo naman matatanggal susi kapag di mo nilagay sa Park ang kambiyo. Just make sure na kapit ng todo ang handbrake at wala ng magiging extrang movement bago ilagay sa Park. Sa sobrang incline talaga gumamit ng kalso. It happened to me before akala ko naka lock na ng ayos yung handbrake ko so lagay na sa Park agad yun nung aalis na ako ayaw mag disengage ng solenoid kailangan pa itulak ng konti para makalog at bumitaw yung prawl.
May 7th, 2015 02:42 PM #1497
Thanks for sharing. To confirm your statement this is what I found in Wikipedia.
"Most vehicle manufacturers[3] and auto mechanics[4] do not recommend using the transmission's parking pawl as the sole means of securing a parked vehicle, instead recommending it should only be engaged after first applying the vehicle's parking brake. Constant use of only the parking pawl, especially when parking on a steep incline, means that driveline components, and transmission internals, are kept constantly under stress, and can cause wear and eventual failure of the parking pawl or transmission linkage. The pawl might also fail or break if the vehicle is pushed with sufficient force, if the parking brake is not firmly engaged. Replacement can be an expensive operation since it generally requires removing the transmission from the car.."
Tsikot Member Rank 1
- Jul 2009
- 4,090
- Jul 2009
- 4,090
