Results 41 to 50 of 2045
May 25th, 2009 09:13 PM #41
May 25th, 2009 09:18 PM #42
A lemon is a defective car that is found to have numerous or severe defects not readily apparent before its purchase. Any vehicle with these issues can be termed a 'lemon,' and, by extension, any product which has major flaws that render it unfit for its purpose can be described as a 'lemon'.
http://en.wikipedia.org/wiki/Lemon_(automobile)Last edited by XTO; May 25th, 2009 at 09:23 PM.
May 27th, 2009 09:25 AM #43
i encountered a remote keyless entry problem earlier, ayaw na sya mag function and all i have to do was use the key manually to lock/unlock the door. did so many resets on the code alarm's dash button with the help of winterpine's tech, but to no avail.
after a couple of days the head of winterpine called and instructed to remove the battery of the steering audio remote and back. voila, the remote keyless entry went back to life. meron yatang interference between their frequencies. if ever daw na mangyari uli, winterpine will replace the steering remote.
just a heads up kung sakaling may maka encounter ng ganitong problem.
May 27th, 2009 09:29 AM #44
May 27th, 2009 10:04 AM #45
hello po sa inyo!
yung steering remote ko naman po merong times na ayaw umandar. hindi nagrerespond yung HU when i press the buttons. i'm thinking it could be the battery. i haven't replaced it yet. palitan ko ng bago once magloko sya ulit.
- Jan 2003
- 40
May 29th, 2009 05:25 PM #46Clarification lang:
What I was complaining about was the air leak on my airconditioning unit. May buga sa ilalim ng console going to my feet even if my airflow setting is towards the face. Normal lang daw yun, will have it checked na lang pag nagupgrade na ko ng sound system para isang baklasan na lang.
As to my 5k PMS, yes 2 liters of Synthetic Oil BUT I did get the remaining unused oil. Halos 1/4th lang nabawas dun sa 2nd liter. Mahal lang talaga oil filter so 2,100 is not bad at all.
- Jan 2008
- 3
June 2nd, 2009 01:49 AM #47
have similar problems with my remote keyless entry, hassle pa kasi isang beses malakas and ulan and when i left the vehicle ayaw mag lock kahit na anong pindut ko sa remote. i waited din kung mag auto-lock siya pero ayaw din. it does not happen often pero once in a while nangyayari pa rin. at least i have an idea to remedy the situation next time. thanks for the info.
June 2nd, 2009 02:21 AM #48
- Jan 2008
- 3
June 3rd, 2009 10:02 AM #49
June 3rd, 2009 01:44 PM #50
according to peter of winterpine, the casa techs can't do anything about it because they are the one who installed it. if it was an engine or other mechanical defect then they can service it. so, it's best to inform your SA so they can forward your concern to winterpine. nakaka irita minsan kasi na kabago-bago lang nag sasakyan mo, susi ang gamit mo pag bukas at pag locknakakahiya din tingnan sa mga katabi mong nakaparada.
Tesla Philippines
