Results 1 to 10 of 16
- May 2008
- 22
October 28th, 2016 11:38 AM #1Pardon my ignorance. I just got my G4 about 2 weeks ago. I wanted to check on the temperature but don't know how. Nag wawarm up kasi muna ako ng car before using it pero there's no way for me to check if it reaches the right temperature unlike with the old cars I used before. So I just rev for about 3-5 min. And how will I know when the time come na mag overheat (knocking on wood)? Thanks.
- Jul 2010
- 165
October 28th, 2016 12:01 PM #2On most cars, upon start up it will display an engine temperature light which is color blue on the cluster gauge. It will turn off once your reach the optimal temperature for the engine.
You will only notice that you are overheating once you see an engine temperature light which is color red on the cluster gauge
- 53,883
October 28th, 2016 12:06 PM #3i think there is a red light that lights up when the engine overheats. other than that, there's nothing we can do to monitor engine temp. it's frustrating, but at the price...
btw... warming up the engine, using up fuel and spewing out pollutants, all without going nowhere, is a waste of fuel. just drive out, po. let the engine take care of itself.
October 28th, 2016 12:49 PM #4
OP, everything you need should be in the manual.
Low coolant temperature indicator - green
This indicator comes on in green while the coolant temperature is low. NOTE: When the indicator goes out, this should be used as a rough indication of when the heating starts working.
High coolant temperature warning light - red
This light comes on in red if the coolant temperature becomes excessively high. CAUTION: If the light comes on during vehicle operation, it indicates that the engine is possibly overheating. Continued driving could make the engine fail. Immediately stop the vehicle in a safe place and take appropriate action.
- Oct 2013
- 2,537
October 28th, 2016 12:58 PM #5
- Oct 2016
- 8
October 28th, 2016 01:06 PM #6normally new cars don't have a temp gauge like the old models. It will only alert you when it reaches the maximum heat temperature. I suggest to look at your user's manual to see what temperature logo looks like. I don't know if all cars have the same logo whent it comes to temperature.
- Oct 2016
- 8
October 28th, 2016 01:10 PM #7
October 28th, 2016 01:50 PM #8
This is the universal symbol for engine temp.
Here's the link to the online manual for the Mirage: Download 2 15 Mitsubishi Mirage - Owner's Manual PDF (3 Pages)
Do note that some specifications varies according to vehicle's target market. But for the most part, the manual for the same model car is about 95% identical, worldwide.
- Jun 2015
- 2,751
October 28th, 2016 02:21 PM #9If you prefer real-time temperature reading you should get a Bluetooth OBD dongle + Torque on your smartphone.
Tapatalked
October 28th, 2016 03:02 PM #10
Having a temp gauge is a bit overrated for these small modern cars. Manufacturers have gotten engine coolant temperature control down to an almost perfect science. A lot of people has a perception that once this indicator blinks red, your engine is toast.
Not so.
When the temp indicator turns red, it doesn't necessarily mean that it's the death of your engine. It is however, heading in that direction if you keep operating the vehicle in that condition.
The key here is to occasionally glance at your instrumentation dials ever so often to make sure that none of the warning or caution lights are on. Whether or not your engine coolant temp is represented by a gauge or just an indicator light, they're of no use if you don't check them and/or act upon them.
