Results 1 to 10 of 16
- Sep 2003
- 342
July 13th, 2004 04:32 PM #1yung pajero ko biglang ayaw mag heat so yung start sa umaga medyo natatagalan compared sa pag may heater....
usually may ticking sound that would indicate na tapos na siyang nag heat but i notice lately wala yun..pina check ko at oks naman lahat ng fuse at mga relays...so alin kaya ang sira why ayaw mag heat...any idea?
Tsikot Member Rank 3
- Dec 2002
- 551
July 13th, 2004 04:54 PM #2baka sira na ang heater plugs. not sure about the name. had the same problem with mine just replace the 4 pcs then its as good as new
- Sep 2003
- 342
July 13th, 2004 05:08 PM #4
It's glow plugs.
Madali lang check kung gumagana pa ito, remove them one by one so you will not get confused. Using two wires to connect them directly to your battery on each polarity. Careful, glow plugs do get hot. And hold the positive wire away from vehicle body. Healthy glow plugs should get hot and literally glow in red in a matter of seconds.
- Dec 2002
- 551
- Sep 2003
- 342
- Sep 2003
- 342
July 13th, 2004 05:19 PM #7actually pde din heater plug ang itawag...
http://www.picotech.com/auto/glowplug.htm
pero di ko alam san ko hahanapin dun sa engine bay mga ito..
- Dec 2002
- 551
July 13th, 2004 05:25 PM #8if your looking at your engine its on the right side there will be 4pcs of sticks protruding out
they are side be side with 2 inches gap from each other
btw whats youir pajero 4d56 ? 4d56 turbo, 4m40 ?
July 13th, 2004 05:25 PM #9
Its likely that your GLOW PLUG RELAY is kaput!
Bili na and replace!
This is the component that produces the 'tick' sound every morning. And please make sure that this is the MAIN relay, located in the engine compartment, behnd the batt. Sure ako becauise this happened to me in my previous Pajero.Last edited by pajerokid; July 13th, 2004 at 05:30 PM.
- Sep 2003
- 342
Tesla Philippines
