Results 11 to 20 of 214
April 17th, 2010 06:43 AM #11
Ang itim agad ng langis sa 4d56 kahit kaka changeoil pa lang. I'm using Castrol GTX 15w 40.
April 17th, 2010 11:48 PM #12
oo nga,,sadyang madumi talaga ang diesel after changel oil after 1week tinry ko lang mag change oil pag start mo madumi pa din
April 18th, 2010 10:42 AM #13
- Apr 2009
- 429
April 18th, 2010 11:40 AM #14
Hi, sir. It does not really matter what type or brand of oil you use as long as it is within the factory specs recommended in your owner's manual. And whether you are using mineral or synthetic you should change your oil and oil filter every 5,000km or 6 mos whichever comes first. Yes it is expensive but it is far, far cheaper than having an engine rebuild. By experience, imported oil brands are far better than the ones offered by the local companies here. I'm sure you know the answer. Your guess is as good as mine
April 18th, 2010 11:43 AM #15
Okay lang na dumumi oil mo ibig sabihin effective ang cleansing agent ng langis . Gawin mo magpalit ka na lang ng mas maaga sa recommended na change oil ng makina.
April 18th, 2010 11:54 AM #16
- Aug 2009
- 48
April 18th, 2010 12:31 PM #17hindi naman maselan ang 4d56, caltex gold, rev x will do, if it is with turbo a multigrade will do.......
- May 2009
- 119
April 20th, 2010 10:55 AM #19just have a recent oil change petron HD lang nilagay ko sa 97 FB ko at replacement oil filter lang...di naman maselan ang 4d46 basta follow the 5K kms interval of oil change but if you has extra money to spare try nyo delo gold multigrade swabe ito I use it on my crosswind....688 per 4 liters....
- Mar 2010
- 15
