Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Mga mitsubishi experts and pajero owners...
    My 2003 pajero has a knocking sound (tac-tac-tac), continously and loudly upon pressing the accelerator pedal in a rush (PA-BIGLA).. as early up 1.5 rpm, the knocking would start and never stop... BUT (weird part)... if I will accelerate it slowly.. kahit up to 3RPM, walang knocking sound...
    I had two mechanics checked, they can't diagnose the problem.., ang sabi lang OVERHAUL daw kailangan... huhuhu...
    any help will be appreciated... thanks
    may pahabol tanong pa ako...
    kapag palitan natin ang mga shocks ng 2003 pajero to GAS type, nawawala po ba ang options ng Soft-Moderate-Hard? At patay na rin ang ilaw ng tire sensor ko...
    Alanganin ko dalhin sa CASA kasi I'm sure patay ako sa gastos....
    any help anyone?
    Feb 2009
    Quote Originally Posted by Dudee View Post
    auto trans?
    check mo muna timing, valve clearance, pede rin fuel knock yan, check for air in the fuel line. finally mag pa compression test ka. if all checks out baka katok na yan ng conrod bearing. how many kms na tinakbo?
    Quote Originally Posted by afrasay View Post
    61T mileage.. matic transmission.
    I recently had it oil changed, and change atf using shell DONAX... ok po ba ang DONAX?
    If your mechanics has an automotive stetoscope and technically knows different engine sound, they can easily identify and locate that knocking sound. Saan po ba location nyo? Kung malapit lang sa amin I'll identify it for you for FREE
    of charge
    Quote Originally Posted by electricx View Post
    of charge
    thanks.. taga probinsya po ako..
    any help anyone?
    afaik mawawala na yun pero hindi mawawala ilaw ng tire sensor mo sa mags nakalagay yun sensor nun.
    Jan 2010
    may ganyan din ako dating problema. sabi sakin nagloloko daw yung EGR ko. ginawa ng mekaniko pinasakan ng pako yung vaccuum tube na nagcoconnect ng EGR at intercooler. nawala agad yung tunog. try mo po baka sakali gumana.
    Quote Originally Posted by iennod View Post
    what do you mean "pinasakan ng pako"? Is it normal to have dark smoke (upon rev) coming from the vacuum tube (if not connected with the intercooler)?
    How do I check if the intercooler is still functionable?
4m40 knocking sound (acceleration)
