Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
    Feb 2013
    Kapag papalitan ang front brake pads ng 2014 Mitsubishi Mirage G4 GLS, mas recommended ba na CASA na direcho pagawa para original parts na gamitin? Or ok lang yung mga Japanese replacement brands outside na cheaper?
    Quote Originally Posted by kevindd992002 View Post
    casa replacement is hecho derecho and is the most expensive choice.
    you can buy the pads in the casa, and have your local mechanic install them, to save on labor cost.
    you can buy the pads at a genuine oem store, and have them installed by the store's tambay mechanic, and probably save a bit more.
    you can buy a good non-oem replacement and have friendly mechanic to install it, at even more savings.
    you can save on labor cost, if you install it yourself!
    Feb 2013
    Thanks!
    Any recommendation for a good non-oem brand?
    Jan 2003
    Thanks!
    Suggest you buy OEM as some non OEM replacements tend to be noisy and eat through the rotor.
    Jul 2013
    Thanks!
    Original Bendix is good and quite popular. "Original" because it seems that there are fake Bendix in the market already.
    I suggest buy the brake pads from casa, have it installed outside. Or if you are a DIY type of person (like me), install it yourself.
    Replacing the pads is easy. What's tiring is jacking up the car and removing the wheels.
    Feb 2013
    Quote Originally Posted by Lew_Alcindor View Post
    I see. So does the casa provide original Bendix as their OEM part?
    Thanks!
    bendix ph and brembo ph both on fb
    speedyfix and motech and other shops can install them. you can also ask if they have brake pads for your model. make sure they lube the caliper pins..
    FOCUS
    Jul 2013
    Ask the casa, not me.
    Get Brembo OEM replacement pads if they have them for the Mirage. What they offer me for my Fozzie is cheaper than the one from the casa.
    Feb 2013
    Speedyfix quoted 3700 plus 400 labor fee for Brembo. I'll try inquiring from Motech to compare.
Replacing 2014 Mitsubishi Mirage G4 GLS Front Brake Pads
