Re: 2011 Mitsubishi Montero Sport [continued]
Quote:
Originally Posted by
zix888
Yup, halos synchro yan sa diesel warning sa instrument panel when it shows, usually dun nagbablank yung sa MIS. meron pa reserve na 10 liters more or less. I tried topping up as soon as the MIS goes blank, in 3 readings halos 10 liters nga ang reserve
sa akin hindi synchronized sa low fuel warning lamp
in my case, blank na ang reading sa distance to pump in my MMS but my low fuel warning indicator lamp is not yet blinking.
i can still drive about 10kms and manage to get to the gas station but my low fuel warning indicator is still not blinking.
at this point, the gas gauge needle here is a bit lower now than the second to the last line though not anywhere near the empty fuel line
:happy:
zix888
Oh in that case, we have different MIS setting, coz definitely our fuel warning will illuminate at the same level of fuel left, since pareho lang mga tanks and floaters natin, right? Dapat pala actual na lang pagcheck how far pa it can go when the MIS go blank since different pala settings ng mga MIS natin. Have you tried checking how many liters left when your fuel warning blinks?
actually, i prefer it to be synchronized to lessen guesswork
will monitor muna
i just had my RV meter changed and let's see if it will be synchronized now
:happy:
blank reading starts at the last line before hitting empty.
Synchro talaga yung fuel warning ko sa pagblank ng distance to empty ng MIS kO. Eto kakatop-up ko lang
zix888
thanks. no wonder sira yung last 2 rv meters ko. on both occasions, the reading goes blank even without the low fuel warning. then the figures for average speed and FC also freezes
this was a symptom of a busted rv meter
:grin:
111prez
:grin:
waaaah sira din pala talaga yung ipinalit sa MID ko!:twak2:
Good Day,
Just would like to ask to those MS owners that installed a headrest monitor kung DVD lng talaga ang pwede idisplay nung monitors? The winterpine personnel tested the unit with a movie saved in a USB and an ipod movie ayaw magdisplay sa monitor, naka color blue lng sya. Called their main branch sa aurora blvd/service dept. ganun daw talaga AVT head unit, DVD lng daw pwede ilabas sa ibang monitor. Nagbabalak panu ko papalitan yung headrest monitor ng ibang accessories n lng kaso bakit naman itetest nung taga winterpine araneta USB n ipod nya kng d pwede? Inquired also about the TV tuner, wala pa daw rinerelease ang AVT, meron na po bng nakapagpainstall ng TV tuner sa AVT headunit?
Many Thanks
prince777
hahahahaha
marami na tayong ng waaahhhh!
di bale, under warranty naman so obligasyon ng winterpine/autovention na yan to replace it
hassle lang sa oras natin
like i said, sobra talaga ang pull ng kumpanya na yan sa mitsu to be able to supply such crappy products
:twak2: :nonono:
