Page 474 of 501 FirstFirst ... 374424464470471472473474475476477478484 ... LastLast
Results 4,731 to 4,740 of 5006
    #4731
    Quote Originally Posted by babynos01 View Post
    Sir zixx, kapag hinugot mo yung atf cooler hose and inistart mo makina on N, automatic na lalabas na yung old atf? Since binangit dun na 3.5L, babantayan ko pa ba yun or kapag 3.5L na yung lumabas, wala nang mag flow?
    Sana magets mo sir haha )
    Balak ko kasi is kung free flowing ang daloy ng atf dun sa cooler, e ididischarge ko nalang lahat dun while naglalagay ng new one sa filler tube. Kapag iba na kulay yung lumalabas, off na ng engine tapos measure nalang.
    Posted via Tsikot Mobile App
    nope! kasi yung level ng lines going to/from cooler sa tranny side is not same level sa bottom part niya. kaya hindi lahat madrain kahit paandarin siya. you really need to remove the drain plug. no short cut bro
    #4732
    Quote Originally Posted by zix888 View Post
    yan ang ayaw ko gawin sir, kasi walang plug and play na gasket para sa pan. allergic ako sa gasket maker
    yaiks..
    Madugo pala. kaya pala nung sinabi ko sa casa nung 40k na pati screen filter paltan, sinabihan ako na hinde pa advisable.
    Thanks Master.
    Feb 2007
    #4733
    Bro zix, i got the MD050317 instead for the DP GASKET. ;)
    Click image for larger version.
Name:	ImageUploadedByTsikot Forums1408779139.707575.jpg
    Sent from my Nokia5110i-VgT using Tsikot Forums
    #4734
    nice find!!!
    Feb 2007
    #4735
    Just found out that aside from adding to engine oil, this can also be used for transmission oils.
Name:	ImageUploadedByTsikot Forums1408789104.271270.jpg
    Sep 2011
    #4736
    May I know why sir? Nababa na panu yung pan ko, yung "gasket" nya parang paste lng di kagaya nung sa EGR na bakal. Kailangan i strip yung nakadikit na gasket then may linagay na high temp silicone gasket ata
    #4737
    Quote Originally Posted by butchyboy View Post
    hindi ko lang sir type yung gasket maker, if may oem na gasket lang sana, sigurado ibaba ko din yan pag nagchange atf ako.
    my axles, feeling happy
    rear axle * 40k kms
    front axle * 50k kms
    transfer case * 50k kms
    #4738
    ^bro ok ba yung Top1 gear oil?
    Sent from my Nexus 7 using Tapatalk 2
    #4739
    sa transfer case ko ginamit. 50k kms tinakbo, okay naman
    Sep 2005
    #4740
2011 Mitsubishi Montero Sport [continued]
