Results 3,971 to 3,980 of 5006
Tsikot Member Rank 1
- Jul 2009
- 4,090
June 8th, 2013 08:53 PM #3972
- Jun 2013
- 14
June 8th, 2013 09:47 PM #3973SIr Glenn, Did ou mean The Automatic Transmission Fluid Level, I checked all the fluid levels at vital parts as part pre-trip visual inspection and 360 degrees visual inspection sa car. ung mechanic na ang nag open ng drain plug, as far as I remember walang problema ang differential housing any dents or unusual marks.
- Aug 2003
- 317
June 9th, 2013 02:28 AM #397430k kms ang casa interval for changing Differential fluid. So during your 5k PMS sir I am 100% sure that they did not check the fluid level. Kasi visual inspection lang ang gagawin nila diyan (kung ginawa man nila). That is why I am emphasizing that kung talagang the cause is the lack of differential fluid, the one who should have inspected it during the Pre-Delivery Inspection should be the one held liable..
Take a look at this diagram of the Rear Differential Assembly..
ESSI24 - A/T..CARRIER ASSY,DIFF - REAR AXLE - REAR AXLE DIFFERENTIAL - PAJERO/MONTERO SPORT(EUR/MMTH) - ????? ??????????? - ?????? - Mitsubishi - ??????? - ???????????? ???????? - ?????????? - ????????
I don't know what part failed based on the actual picture shown.. I am guessing it may be the diff drive bearings due to the lack of lubrication?
June 9th, 2013 12:53 PM #3975
Thanks for the info sir Larry, Nangyari na kasi yan sa isang pick-up namin dito sa site, naubusan ng differential fluid, sumabog din. Sumabit kasi yung rear differential sa bato while crossing a river, nasira yung pinion seal, nag leak. Parehas yung itsura ng damage sa picture na post ni sir Zix, although yung sa case namin nagka butas yung differential housing nung sumabog.
Ang extreme cause na naisip ko dyan ay ginalaw ng mekaniko ng casa sa 5k PMS ninyo yung drain plug, Kung kulang na kasi yang langis from the factory hindi na aabutin ng 5k km yang differential ninyo at maririning ninyo yung whinning sound. Kung may defective oil seal naman, dapat may mapansin kang leak o oil sa garahe mo.
June 9th, 2013 01:00 PM #3976
- Jun 2013
- 14
June 9th, 2013 03:10 PM #3977Walang leak talaga kasi nag 360 degrees visual inspection ako kasi malayo ang pupuntahan namin vital parts and differential eh. Walang tama ang differential ung filler cap kung saan nilalagyan ng oil nagkaleak na kasi ang tendency ng metal pag masyadong mainit nagexpand na. wala un na sinilip ko eh.
- Jul 2009
- 4,090
June 9th, 2013 05:24 PM #3978
- Jul 2009
- 4,090
June 10th, 2013 01:24 AM #3980
