Results 501 to 510 of 5006
- Mar 2011
- 5
May 20th, 2011 01:41 PM #501
- Apr 2011
- 109
May 20th, 2011 04:41 PM #502Hi eccm, inquire ko lang if how reasonable is the price of the upgrade and if what was done on your unit. Winterpine (in amcar sta rosa, laguna) cannot install the avt subs with built in ampli in my unit due to some other items needed to install it that they still donot have, for almost two months now. Hope you can pm me on this. Thanks/
- Jan 2011
- 141
May 20th, 2011 09:15 PM #503
May 20th, 2011 10:01 PM #504
Most deadeners are primarily composed of butyl. You wouldn't like asphalt since mangangamoy yan on a hot day (especially pag nasa Pinas ka pa). Madaming kinds, liquid deadeners, etc. but most of the deadeners you find in the market is of the butyl kind -- Dynamat, STP, Stinger Roadkill, etc. Technically speaking, these are called CLD (Constrained Layer Dampers) and traditionally used to control panel resonance (hence for car audio purposes sila normally). A cheaper but less effective alternative are those foam mats. Ito mga Acoustimats. They're roughly half the price of a STP Silver butyl lining.
That 100kg is an approximate weight added on to a fully deadened sedan using those butyl mats. And that's not even overkill. Some car audio purists even use mass loaded vinyls (MLVs) on their vehicles just to isolate noise. More mass = less noise penetration.. very simple science. It's like using a thick door versus a thin door in isolating your room from outside noise. How heavy are MLVs? They're like a substitute for leadone of the most dense elements in our Table of Elements.. Bwahaha..
If you're not planing on foray into car audio, just those foam mats from Acoustimats would suffice. These are often called OEM mats since pagbinaklas mo door mo, you'll probably see them slotted inside your doors.
Acoustimats is around 800php per sheet ata.. you could get them 500php kung may kilala ka though (trading section of different forums). Most doors need 2 layers/sheets to cover the "front and back". Personally, got no idea how much whole car deadening using them would cost.
EDIT: Is it practical for a daily driver? No.Last edited by jhnkvn; May 20th, 2011 at 10:10 PM.
- Apr 2011
- 540
May 21st, 2011 12:28 AM #505BTW, Mickeys autosound already has cables for the headrest monitors....plan to have my audio setup installed by them.
May 21st, 2011 12:45 AM #506
- Jan 2010
- 18
May 21st, 2011 10:53 AM #507
- Jan 2010
- 18
May 21st, 2011 10:55 AM #508
- Feb 2011
- 563
May 21st, 2011 01:45 PM #509I think Mickey's has a variety of seps to fit your budget, but remember you still have to add wirings, the cable for the avt hu to install the sub and of course the seps. decent wiring kits would go for 4k minimum. May mga generic at 2.5k
If the budget na 10k is only for the seps then you have a lot of choices like morel, focal, hertz, etc
May 21st, 2011 01:49 PM #510
Personally, I would recommend Banawe for budget meal setups
since most of them offer free installation and stuff. Not to mention alot of the shops there offer "packages" if you're off to a fresh start. But if you're after quality work, Mickeys are really worth the buck. Yun leatherette na ginagamit nila is soft.. it's the expensive one daw according to Rocky (yun owner ng Mach2Audio just a few blocks away) na pagmay shipment, agawan mga dealers sa material.
For the seps, if you're budget is from 8,000-10,000php: I would recommend just two: Morel Tempo 6 and Focal's entry-level separates, 165A1 Access. But Mickeys have sort of "premium" pricing. Although you can haggle the price, masmababa parin sa Banawe (due to lots of competing shops). Problema with Banawe is that: pagwala ka alam, they would likely fool you.
I'd suggest Candyshop sa Banawe. Look for Nogs, super mabait yun. In fact, wala sa mukha niya ang pagiging "boss" umpisa akala ko employee lang nga siya ehLast edited by jhnkvn; May 21st, 2011 at 01:54 PM.
