Page 186 of 206 FirstFirst ... 86136176182183184185186187188189190196 ... LastLast
Results 1,851 to 1,860 of 2054
    Feb 2011
    #1851
    after my 1kpms ganito nangyari... magugustuhan ninyo ba ganito?
    http://www.flickr.com/photos/59912833*N03/5528100302/
    Mar 2011
    #1852
    Quote Originally Posted by don View Post
    thank you sir big help
    guys how to reset this
    i only have 800 on the odo
    The periodic maintenance comes out when you reach 800 kms. And will only be removed when you had the unit undergo the 1000 PMS. A new reminder will come back before you reach the 5000 km PMS and so on. Part of their regular maintenance reminding system.
    Feb 2011
    #1853
    Quote Originally Posted by elisher0210 View Post
    Is that on idle or were you stepping on the accelerator? Also, fully synthetic oil (from casa) was used after your 1kpms?
    #1854
    Press the center of the triangle and hold for a couple of seconds until you see a password required board, enter 6923
    May 2008
    #1855
    hi guys. what do you think of installing a turbo timer on MS GLS V?
    also can you post some pics of your sound set up for monty? im planning to upgrade the sound system but my budget is 10K.
    any suggestion for shop?
    Feb 2011
    #1856
    Quote Originally Posted by crumpled View Post
    yes sir my casa put fully synthetic oil.. idle mode... after we go to church...
    Feb 2011
    #1857
    Jun 2009
    #1858
    Quote Originally Posted by gundam View Post
    based on the many posts here, personal experience and videos. now i'm under the impression that the smoke issue is experienced only in gls-v. why??
    for the comments/inputs. i thank you. fellow tsikoters.
    in relation to this smoke issue. my gls-v is white. if i open/close the tailgate and my sweaty/ oily fingers touched the cladding. if i use the car for a day, the next morning i can see black fingerprints. ala CSI. hehehe..
    Quote Originally Posted by gti277 View Post
    Neither do I. I don't understand why it's only for GLS-V though they share the same engine Is there a discrimination here?
    I have the same experience bro. White GLS-V, always find fingerprints/ dust on the tailgate garnish. Punas lang naman tanggal na
    ganun din akin
    If it is common to GLS-V only.
    It maybe due to the difference in the transmission low gear ratio between the two variance. Especially if you compare their first gear ratio.
    If CRDI engine cannot reach high rpm fast enough (because of initial load) + many diesel = :horse: still many horses but with some or plenty of droppings depending on the amount being fed hehehe
    Comparing the two variance, the GTV engine is loaded less most of the time especially when driven from stand still or heavy traffic because of the very low first gear of the GTV.
    When their accelerator pedal is pressed hard in the same manner, the GTV should also reach higher RPM faster and easily compared to the GLS-V, the unburnt fuel (if there are) should also be lesser thus less smoke.
    Of course, their is still the better/ fuel-efficient option to press that GLS-V accelerator pedal gradually during the initial acceleration and feel/play with its power once it reaches 1800rpm or bit higher.
    Jun 2009
    #1859
    Strange considering wala naman snow sa pinas... in cold areas common kasi yan.
    hope malaman ang talagang dahilan kung bakit ganyan yang unit ninyo bossing. At maayos ang dapat ayusin.
    Jul 2006
    #1860
    [SIZE=4]Looking for advice where to buy Car Top Carrier like these which are waterproof.[/SIZE]
2011 Mitsubishi Montero Sport [ARCHIVED]
