Results 661 to 670 of 2054
- Jul 2006
- 3,376
February 15th, 2011 10:24 PM #661Aftermarket HIDs does not invalidate the warranty as long as there is no splicing and cutting of the wires going to the bulb. Installing HIDs is just plug and play, you disconnect the socket powering the stock bulb, remove the stock halogen bulb, insert the HID bulb, plug the wire of the ballast to the HID bulb, and plug the recently disconnected socket to the ballast. Sir xenon headlamp/Richmond, maybe you can correct me if some of what I have typed is wrong.
It does not also invalidate the insurance as per the in house insurance company of Diamond Motor Corp. (Pioneer Insurance)
- Jul 2006
- 3,376
February 15th, 2011 10:28 PM #662Aftermarket HIDs does not invalidate the warranty as long as there is no splicing and cutting of the wires going to the bulb. Installing HIDs is just plug and play, you disconnect the socket powering the stock bulb, remove the stock halogen bulb, insert the HID bulb, plug the wire of the ballast to the HID bulb, and plug the recently disconnected socket to the ballast. Sir xenon headlamp/Richmond, maybe you can correct me if some of what I have typed is wrong.
- Jul 2006
- 3,376
February 15th, 2011 10:31 PM #663For those who already have their VGT Montys, kindly registered at the MSCP forums: http://monterosportclubphil.proboards.com/index.cgi. Thank you
- Oct 2010
- 6
February 15th, 2011 10:40 PM #664Ill go for HID's hirap na kasi galawin ang wires ng montero for safety issues na din, HIDs has 35watts and 55 watts which is better bec. brighter na siya wala ka na gagalawin sa wires mo plug and play na din. and you could choose the color that you think would be nice for you... HTH
- Sep 2010
- 185
February 15th, 2011 11:51 PM #666
dami ko na nakikita nito 1 sa manaog swerte nung owner.. at sa sm pamp.
- Feb 2010
- 21
February 16th, 2011 12:04 AM #667ask lang ulit mga sir, ano ang standard diesel consumption ng montero 4x2 matic city driving?
TIA
- Jan 2011
- 6
February 16th, 2011 12:37 PM #668sir, with all due respect, question out of curiosity only. In my own personal experience a little difference in HP and torque is not that significant on the streets. I see a lot of montys having a hard time "racing" other vehicles and the other way around. I guess a powerful engine does not automatically translate to "the king of the road". May i know the significance of an experienced driver compared to the power of an SUV? peace!
- Jun 2009
- 3
February 16th, 2011 01:07 PM #669Quick comparison with 2010 or older - - the 2011 has more horses, is that a new engine?, touch screen AV LCD with GPS (is that what I think it is?) reverse camera, plus a lot more . . . Why is it cheaper? I planning to buy this one vs the Fortuner or the everest unless there is something we don't know yet? I got the specs below in case you havent seen them yet.
: 2011 MITSUBISHI MONTERO SPORT GLS 2.5 VGT 4X2 Diesel A/T
2477cc 4D56 DOHC 16-valve EFI Variable Geometry Turbo (VGT) with Intercooler CRDi diesel engine, 178ps/4000rpm maximum horsepower, 35.7kg-m/1800 to 3500rpm, 4-speed INVECS II Automatic Transmission w/ Sportronic Mode, 3-spoke leather wrapped steering wheel w/ integrated audio control switch, MMAD single-in-dash DVD/MP3/WMA/MPEG4/tuner/USB port/iPod ready/Audio Jack/Bluetooth connectivity/Reverse Camera ready/7” touch-screen LCD monitor with integrated Multi-Information Display (MID) and Navigation System, manual controlled air-conditioning system, Dual front SRS airbags, 16” front disk/11.6” rear drum brake system w/ ABS and EBD, double wishbone coil springs front suspension w/ stabilizer bar, rear 3-link coil springs suspension with stabilizer bar, 7 adult seating capacity, black water repellant fabric seats, manual (slide, recline and height adjust) driver seat, power windows, power adjust side-mirrors w/ one-touch auto-fold function, color-keyed tailgate garnish, tailpipe finisher, keyless entry alarm system, 265/65 R17 tires on 17” x 7.5J alloy mags wheels, CEDP, 3 year anti-rust warranty and other standard factory specifications.
February 16th, 2011 01:39 PM #670
