Results 1 to 10 of 11
- Aug 2003
- 9,720
September 23rd, 2014 11:52 AM #1Hi peeps, saan makakabili ng ganito, yung ginagamit pang airbrush?
Actually ang intention ko is to do some regular cleaning in our server room; the dust gets so bad that it clogs up the vents in our equipment. Yung vacuum cleaner na nilalako sa Ace, the one with the blower function, sobrang hina. Pag full-size compressor overkill naman.
i think it's about time the office got one, kakahiya na humiram kay bro ^_^
September 23rd, 2014 12:39 PM #3
Air compressor? Air brush? Scale model hobby shops sell them. Any would be adequate so long as they are capable of at least 40 psi.
I'm not sure it's a good idea to use an air compressor to clean out the insides of servers because of the micro droplets present. Outside should be okay.Last edited by Jun aka Pekto; September 23rd, 2014 at 12:42 PM.
September 23rd, 2014 12:43 PM #4
I have a Kawasaki mini compressor sitting unused at home. Ginagamit ko for airbrushing back when I was single and had all the time in the world to paint 1/35 scale tanks.
Wala akong regulator so I made do with whatever output it can give me. As it is I don't think its output is strong enough to blast dust away.
- Aug 2003
- 9,720
September 23rd, 2014 02:52 PM #5
September 23rd, 2014 10:50 PM #6
From my own experience, the moisture accumulation from using an air compressor cannot be avoided unless the operating environment is very dry. Water vapor is always present. When air is compressed, the same goes for water vapor which shows up as condensate.
The Philippines is so humid, I wouldn't recommend air compressor output to clean out the dust from electrical components. I'd use canned propellant instead. Even with that, I'd still be careful and use short bursts because condensate can easily form on the can if you use long bursts.
September 24th, 2014 10:14 AM #7
You can use a water separator (or two) and a very long clear hose para visible ang moisture. It won't remove all the water pero it's good enough for airbrushing. I still wouldn't risk using it on electronics though.
- Aug 2003
- 9,720
September 25th, 2014 11:58 AM #8sirs good idea ba to use a manual tire pump for cleaning? Or is it still susceptible to moisture buildup?
September 25th, 2014 12:40 PM #9
- Sep 2008
- 699
September 25th, 2014 01:02 PM #10Hi badkuk, I think the best solution for your server room is positive air pressure from your A/C system. This is to ensure that no more dust will come in. After you have remove the dust of course. cheers
Tesla Philippines
