Results 1 to 10 of 27
April 9th, 2019 05:34 PM #1
meron ako. Gingamit ko lang pag meron event sa bahay. Meron mga fittings na kasama for the xhaust pwede mo install sa ceiling para Isaksak na lang doon yun exhaust pwede din ipit sa sliding window pero open yun window unless papasadya mo yun exacto lang para doon sa bracket ng exhaust para closed pa rin yun window.
I'm talking about real portable a/c ha not yun air cooler lang.
Problema lang kailangan itapon yun condensation so mag stop siya pag puno na ng tubig. Istorbo.
Kaya kung sa Room ng baby mo pag kabit ka na lang ng split type kung ayaw mo mag butas.
April 9th, 2019 05:43 PM #2
kung maliit lang ang room, meron naman available na ventless... kaso just like the single vent solution, medyo alangan ako.
kung dual hose naman, medyo mahal.
- Jul 2013
- 2,450
April 10th, 2019 09:58 AM #3Another option is to have a window modified to accept a window type aircon.
April 10th, 2019 10:14 AM #4
Madali naman i-patch up yung butas sa pader just in case you decide to remove the split type.
But with this weather I bet di mo na iisipin yung butas pag nakabit na yung AC.
April 10th, 2019 12:42 PM #5
What a timely thread. I was actually looking at online ads for a portable A/C. But I have a different use case.
With summer here, I'd like to cool my IT "cupboard"-type cabinet at home. It's around 1.5 x 1.5 x 1.2 meters (W x H x D) or just roughly 3 m³ in volume.
All equipment (3x servers, switch, monitor, AP, and other ancillary components) consumes around 250W, ±20%. That roughly translates to around 850 BTU/hr of generated heat. In fact, just within the month, one of the servers which is installed quite near to the ceiling crashed showing an amber health LED indicating that it has preemptively shutdown due to overheating. Moving the server is not an option so I will have to cool down the whole space during the summer.
I am looking into designing a small A/C out of automotive A/C components. Does anyone (or do you know somebody) who has ever succeeded in fabricating such?
- Feb 2014
- 2,658
April 10th, 2019 12:49 PM #6
April 10th, 2019 01:52 PM #7
a. The cabinet is nowhere near a window. It's in an 'island' between my living room and dining area
b. Watercooling is likely to be ineffective as the ambient temp in the IT cabinet can reach close to 37°C. Two of my servers are only rated at 35°C max. ambient temp, and as mentioned previously, the one on top gets the brunt of it. Also, beyond the CPU, I can't watercool everything... RAM, chipsets, hard drives, etc.
This is the ambient temp reading for the last 36 hours in the area where the server in question is located. Notice that even during the wee hours of the morning, the temp barely goes below 34°C. It only goes down whenever the living room A/C is running.
This is the actual picture of the setup, taken a few minutes ago.
- Feb 2014
- 2,658
April 10th, 2019 02:00 PM #8how about putting your entire servers into a chest freezer
then run it at a fairly warm settings, dunno if that's possible though...
but i'm really interested on how to crank a car a/c compressor. but for different reasons
- Jul 2013
- 2,450
April 10th, 2019 03:09 PM #9
April 10th, 2019 03:50 PM #10
As a matter of fact, this is the direction I'm considering. The cabinet already has a 4-inch PVC pipe going to the attic. A custom/fabricated mini "split-type" A/C will be ideal. Control is through a thermostat and/or home automation.
As it is, with the room A/C off (a 2.5HP inverter split) the living room and dining room are just a few degrees cooler than my IT cabinet. I'm looking at having the cabinet actively cooled with the heat expelled through a condenser installed in the attic. That way, I don't inadvertently warm up my home and tax the existing room A/C.
I have three (3) servers now with the possibility to add more in the future. Is there a liquid cooling solution that can pool all servers' plumbing into one big radiator? I don't want three or more sets of hoses going in and out along with three radiators outside.
This is plan B. If it can be helped, I would like to dump the hot air outside the house (or to the attic). But not through ventilation. Doing so will create negative pressure inside the house and reduce the effectiveness of my existing room A/C.
Tesla Philippines
