Results 11 to 13 of 13
March 3rd, 2012 09:26 AM #11
Q no. 6 is limited. if the car manufacturer is not on the choice, and you filled up the 'other' box, you cannot go on with the survey cause the message that appears requires you to mark any of the tick box. siguro add as many choices.
March 3rd, 2012 09:33 AM #12
Q no. 3 on the part 2 of the survey is tricky. if the answer is no on the previous Q, then you are not required to answer this, but again, you're back to square one. you are forced to fill it up just to get over the survey. maybe delete the phrase "if so" para hypothetical na lang.
