The drawing is just for visualization. In reality, the bottom pipe (outlet) actually punches through about 2-3 inches higher than the bottom of the tank. There's also a separate drain pipe.
We were planning to use a traditional pressure tank (stainless, non-bladder) but I sort of stumbled upon the inverter pumps. On paper, I am liking the features: Quiet operation, low power consumption, WiFi control, etc. Not sure if all that is worth it in the long run, especially on reliability.
Products | Aqua Prime
In my line of work, pumps fitted with VFDs are reliable and highly desired. However, the initial cost to install one is significantly higher compared to conventional motor-driven pumps.
I suggest installing a filter or strainer on your booster pump supply line. You might also consider adding another strainer before your storage tank, which is a more cost-effective solution.
