Results 1 to 7 of 7
- Apr 2009
- 272
April 9th, 2017 12:09 PM #1Can anyone recommend a good mini fire extinguisher na below 1k lang? I saw his flamebeater in lazada nasa 500 lang. Ok kaya yun?
April 9th, 2017 03:00 PM #2
Kiddie fire extinguishers ... don't go cheap on these things ... cheap ones might not work well when you really need them to ...
- Dec 2013
- 680
April 9th, 2017 04:11 PM #3
April 9th, 2017 04:30 PM #4
Even the 10 lbs extinguishers will give you only a few seconds worth of spray. For the car the smaller ones will probably do, but for home use 20 lbs is more suitable. Or several 10 lbs extinguishers.
At home we have 1 Halotron, 1 C02, 1 dry chem and 1 AFFF extinguisher.
- Oct 2009
- 2,271
April 12th, 2017 04:29 PM #5may nabili dati ako sa kapitbahay ko na nag tatarabaho sa refilling shop ng fire ixtinguisher.maliit lang siya..pero 3 years na.sabi kasi na e expired daw ung laman nun.gagana pa kaya un..sabi kasi 1 year lang daw ung validitation nung mga ganun at kailangan daw ulit pa kargahan after 1 year.
- May 2011
- 481
April 12th, 2017 04:42 PM #6Ang apoy hindi nagtitipid. Pag binigyan ng pagkakataon lumalaki. Ingat lang sa mga flammables at combustibles. Pag aralan ang material compatibility
- Jun 2012
- 4,447
April 12th, 2017 04:57 PM #7
Tesla Philippines
