Results 11 to 20 of 163
June 3rd, 2011 12:19 PM #11
June 3rd, 2011 12:25 PM #12
June 3rd, 2011 12:48 PM #13
Pagsummer kasi, super init sa 2nd floor. And mahirap din magbihis ng pinagpapawisa ka.
I've searched the net, and medyo common ng ginagawa ang tile-over-tile. May ipapahid munang tile adhesive.
Floor to ceiling ang wall tiles. Half inch lang naman ang dagdag sa kapal ng tile plus adhesives.
June 3rd, 2011 01:46 PM #14
June 3rd, 2011 03:22 PM #15
maraming klase ang grout adhesive.. di gaya noon kailangan talagang mag tiktik..
June 3rd, 2011 04:03 PM #16
I'm also planning to install a water softener and carbon filter in my main water line. Our relatives/visitors always complain of the smell of our water (nawasa) when they take a bath or brush their teeth. Ang ang tindi din magwater spots sa mga bathroom fixtures and kitchen sinks.
The carbon filter will eliminate the odor and the softener will solve my water spot problem.
My question now is when bathing. How hard will it be to rinse off the soap from the skin. Hindi kaya ako mabwisit na parang ayaw matanggal ng sabon? And baka lumali lang ang water bill ko sa kaka-rinse?
June 3rd, 2011 06:06 PM #17
Sa mga toilet, hindi advisable ang tile-over-tile (although common na ito). Bababa kasi ang water closet lalo na kung naka-fix ito with grout. pero pwede rin kung isasabay na itataas din ang mounting pad niya.
Regarding sa heat sa 2nd floor (mostly 2 storey houses). It is due to heat convection and less exterior openings (operable windows). Solution is to add more vents on the eaves or if possible, roof dormer to draw out the warm air at roof plenum. The best roofing system (cooler) is a multi-layer (like concrete roof tiles over corr. roof sheathing + insulation), but it's expensive and heavy.
If the ceiling is high enough, you can also add a clerestory window (awning type) above the door header to improve air movement inside. It can be closed if the space is cooled with aircon unit.
June 3rd, 2011 07:55 PM #18
I'll be replacing all the water closets in the toilets, so ok lang na tumaas yung floor.
Our windows are huge. 3m x 1.5m each. But in the expanded walk-in closet, ang window lang will be the one in the toilet na maliit lang. Kaya I'm planning to install n parang exhaust fan that will suck in air from the bedroom into the walk-in closet, pero sa taas ng ceiling ang ductings and vents.
June 3rd, 2011 11:55 PM #19
di ba sapat lang yung filters? 4 na yung filters namin sa bahay, nagkukulay na yung mga tiles (namumuti) namin. nawala yung amoy, pero yung kulay na naiiwan sa mga tiles, adun pa rin. btw, water source from our village is deep well. drinking water is of course....binibili.
so separate ba yung filter & water softeners?
June 4th, 2011 12:05 AM #20
Hiwalay yung carbon filter sa softener.
May carbon filter ba kayo? If yes, then the carbon filter should eliminate the water discoloration. Unless maliit ang filter nyo versus your water consumption.
