Results 1 to 10 of 1411
- 53,883
March 21st, 2021 10:57 PM #1the bisagras' alignment moved, hence the difficulty in turning?
or the entire poste shifted, hence the closing edges are now overlapping?
i imagine,
whatever written or implied warranty is in effect, does not cover geologic movement.
on the contrary,
i think a brace should minimize non-rectangular-ness, if it is strong enough.
one below ground and one above the gate.
but then, it might turn parallelogram... more braces?
is this in the same area where a prominent MD's house collapsed as a result of geologic movement?Last edited by dr. d; March 21st, 2021 at 11:06 PM.
March 21st, 2021 11:17 PM #2
Nag dikit pero hindi naman over lapping kaya nasasara pa rin although medyo mahirap. Yung poste daw ang bumaba kaya nag dikit yung 2 gate. Ang mahirap eh ipasok yung bolt latch ng gate dahil hindi aligned although na ayos naman today kaya naipasok na although mawawala na naman sa alignment pag gumalaw bumaba ulit yung poste.
At first I was considering na brace lang sa taas, then your suggestion makes sense na brace sa baba and taas, and then sabi mo baka maging parallelogram [emoji23]. I don't know if I should wait for the ground to settle before fixing, or do what you suggested and maybe it will be a long time before it misaligned again. . I don't want to keep throwing money at it until it's solved.
- 53,883
March 21st, 2021 11:23 PM #3what you can consider, is to do nothing big.
just occasional welding adjustments here and there, so's you can open and close the gate easily enough. i shudder to think how ugly that gate would look like afterward, but at least it's functional.
after some time, the ground may have stabilized.
tekateka...
is it possible, the poste to which the hinges are attached to, was not built sturdy enough?
the ground may be as solid as solid can be,
but the poste was not built with a sturdy-enough base...
March 21st, 2021 11:34 PM #4
I'm not sure about it being sturdy, yung brother in law ko ang nag manage nung gumagawa pero sabi naman nya malalim naman daw yung poste. Dati kasing hills itong lugar namin kaya assumption ko gumagalaw talaga. Or maybe your right, baka kailangan lang mag settle ng lupa.
I think I'll ask for the estimate for braces above and below the gate, then decide from there. Thanks for the tips Doc.
- 53,883
March 21st, 2021 11:39 PM #5
March 21st, 2021 11:42 PM #6
Tesla Philippines
