Results 1 to 10 of 19
June 12th, 2010 06:15 PM #2
back when I had the time to go to the gym, my instructor says it helps lose weight* only if you reduce or eliminate your sodium intake. sodium sticks to water thus resulting into water weight.
The body sets itself into an equilibrium if intake of water is plentiful so you urinate almost every hour because the body is expecting that water is abundant.
it does reduce weight but does it reduce fat?Last edited by Negus; June 12th, 2010 at 06:20 PM.
June 12th, 2010 06:35 PM #3
well, I was thinking like this. ...cold water once enters the body needs to be heated up. The body would require a certain amount of calories to burn to heat up the cold water, hence burning more energy.
Another line of thought went like ... if you eat food with cold water, the body will have to devote more energy to reheat the cold food in your stomach before digestion can take place. Also since it's cold, the food in the stomach will take longer to be digested.
June 12th, 2010 06:45 PM #4
I live in a place with heavy snowfall. I shiver a lot in the morning so my body works hard to heat up. I don't know if that has the same effect as what you've saying but I lost 11 kgs since coming here (I jog once a week in -12 degrees temperature). but I attribute it more to change of diet (mostly fish).
I think your'e on to something. But I think temperatures in the Philippines won't allow you to get you're body to shiver and work hard to heat up.
try mo siguro magpaginaw ka sa aircon sabay kain ng yelo to make you're body shiver.Last edited by Negus; June 12th, 2010 at 06:48 PM.
June 12th, 2010 08:22 PM #6
It's better to drink water at room temperature for the reasons already stated. Cold water takes longer to process.
I usually exercise first before breakfast. I drink tap water afterwards because cold water magnifies my hunger pangs.
If I exercise during the early evening hours, I sometimes drink cold water afterwards since I'm not really hungry yet.
Drinking water as a whole helps lose weight although regulating the types and amounts of food you eat works better. I don't really need to lose weight. I still need to maintain my weight though. That's why I keep a log of the food (type, amount, calories) I eat daily.
BANNED BANNED BANNED
- Aug 2008
- 1,099
June 16th, 2010 03:10 AM #7shucks ang hirap intindihin. pero ako i drink hot water after a heavy meal. lagi ako nanghihingi sa resto para ma-burp lalo na kung overeat. kung heavy meat naman i make sure i drink 1/4 cup of coke light
one thing i've noticed though, parang mas mabilis tumaas ang heart rate ko when walking in cold climate. baka applicable dun yun cold water theory mo na yan. pero tingin you must drink very very cold water
i bring ice-melted water sa gym. bago ko punta sa gym, iwan ko container sa freezer, then i bring tom na iced water na. then sini-sip ko natutunaw na water. i suppose applicable ito kasi 2 weeks ago i was 156lbs bec. of the many food trips sa U.S. now i'm back to 148lbs ulit.
June 16th, 2010 08:12 AM #8i bring ice-melted water sa gym. bago ko punta sa gym, iwan ko container sa freezer, then i bring tom na iced water na. then sini-sip ko natutunaw na water. i suppose applicable ito kasi 2 weeks ago i was 156lbs bec. of the many food trips sa U.S. now i'm back to 148lbs ulit.
BTT:
i would suggest to not make your stomach suffer and just lose weight in the conventional way.
June 16th, 2010 10:06 AM #9
- Aug 2008
- 1,099
June 16th, 2010 01:46 PM #10yeah i was just being polite heheh and encouraging *gh to exercise. si ghost kasi kung anu-ano na iniisip, drinking cold water will make you lose weight heheh
*gh, here's a thought. basta intake, it will never help you lose weight. it's not logical.
papawis lang talaga
Tesla Philippines
