Page 38 of 46 FirstFirst ... 28343536373839404142 ... LastLast
Results 371 to 380 of 451
    Nov 2011
    #371
    same here...
    correct me if I'm wrong. Marcos highway pa din ba easiest way up?
    (I normally only take Kennon on my way back to Manila)
    Answering myself din, last November we took the Tuba Asin Road paakyat. It was fun as usual.
    #372
    Quote Originally Posted by TheUninvited View Post
    how do you get to tuba asin road coming from tplex? saan exit niya pa baguio? salamat
    #373
    Rosario pa rin. But instead of turning right at the Pugo junction to Marcos Highway, you turn left and then the Tuba-Asin Road will be to your right in about 2 km.
    Aug 2004
    #374
    Is it part of Waze's options already or do we have to force it to use Tuba-Asin by ignoring the directions via Marcos?
    #375
    Waze never recommends it. Magreredirect lang if you’re already on the road itself.
    It’s longer by distance and typically longer by travel time in most cases except peak season when Marcos is clogged up.
    Natry na namin yan ng friend ko, sabay from Pugo junction, I took Tuba-Asin, they took Marcos. Sabay lang dumating even if I was driving fast already.
    Aug 2004
    #376
    Thanks! Sige will check my options. Might go Tuba-Asin going up while there's still daylight. Baka Marcos na going down after check out.
    #377
    Beautiful view along Tuba-Asin Road:
    Narrow 2-lane road though and lots of corners.
    #378
    thanks will definily try that. pumunta kami Baguio last dec. sa pozzorubio na ako na pa exit.
    Jul 2013
    #379
    was at Baguio last Nov (when restrictions eased) and going up and down was very enjoyable, wala kasing provincial buses tapos reduced din public transport.
    sometimes I wish na may road to Baguio na only private cars are allowed
    minsan naiisip ko na ang swerte ng car buyers ngayon. we have numerous choices at every price range tapos even entry level cars are "ok"
    wala pa akong nadrive na modern car (2015 and newer) na I can declare "under-powered"
    gone are the experiences of driving a 57hp 4 speed 70's Beetle or the '76 Tamaraw with a 3K engine? The 2E on the XL/XL E100 was also not an enjoyable drive.
    Sep 2021
    #380
    Comment lang, yes, it seems beautiful, but inhabited ba yung area?
    I used to be adventurous din (had an old J40 Land Cruiser back in the day) but compared to then and now where people are depending on you, I don't think I'd chance this road with just one vehicle, kahit daytime pa. Another thing, is there cell site coverage?
    I also wonder what would happen if may big vehicle na nag stall and the road were blocked? There doesn't seem to be a shoulder on the side of the road to go around it, even if you could shift to 4L drive
    More info please, as I'm curious.
Easiest way to go to baguio from manila
