Results 1 to 10 of 44
    Nov 2014
    It shouldn't be. I can think of a few reasons:
    1. The tire is incorrectly mounted: The tires needs to be mounted with the printed yellow circle nearest the tire valve.
    2. Rim is unbalanced from the factory or warped
    3. The tire is excessively unbalanced from the factory
    How much weight in total was added?
    Based from the "Fe5" label, total of 125 grams. If another shop can balance it with at most 4, then I can confirm motech's shenanigans.
    Jan 2009
    125g is borderline, but still acceptable, IMO.
    How about the light spot of the tire (yellow dot or circle)? Is it aligned to the valve stem?
    Seeing Spots? | ABC Tyrepower and Mechanical Rosebery
wheel balancing...
