Results 1 to 10 of 44
July 11th, 2014 03:33 PM #3
nanginginig sa manibela pagmabilis na takbo. usually around 80kph above
Sent from Constantinople
July 11th, 2014 03:43 PM #5
Kung maingay, baka sa goma na.
Fwd, OK lang hindi balance likod pero kung naging maalog, pacheck na rin.
July 11th, 2014 03:52 PM #7
May maingay kasi sa likod... pacheck ko nga kung goma or bearing na.
naka 17 40s kasi ako at nankang ang gulong.
July 11th, 2014 03:52 PM #8
The vehicle speed at which the oscillation starts happening is not the same for all vehicles. It depends on the amount of imbalance, the dimensions of the tire and how tolerant is your steering mechanism. Some have reported 60kph while some only starts to feel it at 140kph.
July 11th, 2014 04:29 PM #9
Wow! Same problem I was about to ask here.
Currently I am also experiencing road noise apparently coming from my rear end. Not sure din kung tire o wheel noise ba yun or kung sa bearing na ba. It started lang kasi since I changed to Yokohama A-Drive yata (confirm ko mamaya). It started barely noticeable. Akala ko dati me tricycle na nakasunod sa akin. Now it's getting worse, even as slow as around 40kph nag-start na umingay. Nagtataka lang ako kasi parang wala naman ako narinig na ingay sa harap samantalang same tire din lang naman. Only difference di ko pa ulit napa-balance gulong ko sa likod. When I bought my wheel and tires kasi kasama na wheel balancing. Pero when I got to SLEX grabe ang alog ng manibela from 80kph pa lang. So pinare-balance ko at naging swabe na. Sa likod same worse balance pa rin. I am thinking to change my rear tires to another brand or another model, pero baka kasi di pa rin ma-resolve. Sayang kasi relatively bagong-bago pa mga tires ko.
July 11th, 2014 04:57 PM #10
Guys ask ko lang. Pag nag tire rotation ba kailangan pang i wheel balancing?
Posted via Tsikot Mobile App
Tesla Philippines
