Results 1 to 10 of 10
- Feb 2017
- 210
November 15th, 2018 08:48 AM #1Mga sir yung gulong ko madali mapudpod yung outer left side.. Yung sa vulcanizing sabi babaligtarin daw niya kasi pudpod na yung kabila, ok lang po ba yun?
salamat po sa sasagot.
- Sep 2006
- 2,746
November 15th, 2018 08:59 AM #2
- Feb 2017
- 210
November 15th, 2018 09:01 AM #3
November 15th, 2018 09:04 AM #4
Usually may “outside” mark sa sidewall ng gulong, meaning yun dapat ang nakaharap. That means hindi pwede baligtarin lalo na pag directional ang thread.
November 15th, 2018 09:12 AM #5
November 15th, 2018 09:14 AM #6
Pa Check mo suspension components mo kung ok, camber alignment then balancing.
Depende kung rotational yun tire mo pwede baligtarin
kung hinde lipat mo na lang muna sa likod
- 53,883
November 15th, 2018 09:48 AM #7as shadow says, "check alignment".
camber siguro. masyadong pike ang gulong.
puede ring toe-in masyado, lalo na kung may feathering.
but if your car is still new-ish, warranty might still cover alignment adjustment for free.
and while you're at it, check tire pressure at baka under-pressure.
never mind the band aid. hindi yan tatagal sa gulong.
good luck.
- Apr 2008
- 6,235
November 15th, 2018 12:39 PM #8Happened to me once. My Westlakes were only around 8tkms in but had used up half of the tread at least on the outer half. Apparently the car was in need of alignment, but I didn't notice because it still ran in a straight line. Ended up replacing the tires anyway at my father's insistence (he drives the car occasionally and often on farther distances [emoji23]).
If the treadwear isn't too bad you can just turn it around. Alignment in my suki shop is only P400. Its when camber is involved that it gets a bit expensive. But then that is maintenance you shouldn't be scrimping on.
Sent from my SM-G900I using Tapatalk
- Dec 2008
- 85
November 16th, 2018 11:03 AM #9Pa wheel alignment muna. Ganun din mangyayari sa gulong na kapalit pag rotate kung hindi aligned.
- Sep 2018
- 77
November 16th, 2018 11:41 AM #10Improper tire alignment causes your tires to wear unevenly and prematurely. I think this is the reason of your car problem. What your mechanic recommended is fine. However, I suggest you include tire alignment on your maintenance schedule regularly to avoid this problem as it's risky to drive with uneven tires. Hope it helps!
Tesla Philippines
