Results 31 to 40 of 87
October 11th, 2016 03:45 PM #31
Pareho lang kaya sila nito?
Portable 12V Mini Metal Auto Car Air Pump Compressor Tire
InflatorGauge 12 - Intl | Lazada PH
Yan o ito ang pinag-iisipan kong bilhin..
CYCLONE Heavy Duty Air Compressor With Working Light (Yellow) | Lazada PH
- Sep 2016
- 38
October 12th, 2016 03:37 PM #32
October 12th, 2016 08:37 PM #33
Malamang yan na kunin ko, free delivery naman at may rebate pa sa shopback, plus may bonus pa na return buyer discount hehe..
- Nov 2009
- 3,503
September 3rd, 2017 02:16 PM #34After 4yrs of use sa 4 vehicles(and sometimes used to prime fuel filters) camshaft lock broke loose causing the cam to misalign. Na stuck up yung piston pero hindi nasunog ang motor.ang galing.
Cleaned and rebuilt, applied lock-tite on those screws holding the cam to the motor shaft and the cylinder.
Solid ang construction neto- zinc body, piston ring made of teflon material, and the sleeve/liner of the bore is well machined.
- Apr 2010
- 740
September 3rd, 2017 02:59 PM #35oil-less ba yung ganyan? have the same model for more than a year now, ok pa rin
- Nov 2009
- 3,503
September 3rd, 2017 03:55 PM #36Yes oil-less, but I have to apply thin film of oil on the sleeves during rebuilding. Siguro para tumagal kelangan din linisin yung sa bearing area dun na accumulate yung dumi. Cleaned using brake cleaner and re-sealed top/bottom rubber gasket with silicon paste.
Nilagyan ko din pala ng polyurea grease yung bearing sa tabi lang to replenish the washed grease, naka press kasi sa cam.Last edited by 12vdc; September 3rd, 2017 at 03:58 PM.
September 3rd, 2017 04:09 PM #37
saw one yesterday all metal... 160psi 35l/min for around 2500pesos. and a slightly bigger one for 5000(didnt check the psi rating tsk) alligator clamps only lol.
Sent from my SM-G935F using Tsikot Forums mobile appLast edited by StockEngine; September 3rd, 2017 at 05:45 PM.
- Apr 2018
- 3
- Apr 2010
- 740
June 11th, 2018 10:43 AM #39After countless 0-35 PSIs on our vehicles and helping other motorists eh bigla na lang tumigil yung compressor. Ginagamit para makatakbo lang sa vulcanizing or totally walang laman ang reserve tire.
Wala namang sira physically on the outside or amoy sunog
Where can I have this repaired (anong shop ba dapat puntahan ko, electronics ba or machine shop or what)
edit: tried PM-ing you pero puno na inbox mo
- Apr 2010
- 740
June 17th, 2018 02:57 PM #40^can't edit my post anymore
fuse lang pala nung power socket ang culprit. noticed my phone wasn't charging and nung binunot ko ang fuse eh open circuit na pala.
wala na yung manual pero IIRC the compressor exceeds the 10A limit for the socket. dunno bakit ngayon lang nangyari yun after years of operation, might modify with alligator clips na lang direct to batt
Tesla Philippines
