Results 1 to 4 of 4
    Aug 2012
    im planning to buy a set of 15" wider offset mags (wider mags than stock) im wondering if my stock tires will still fit the new mags or should i also buy a new set? (my stock rims are 15" too)
    sabi kasi nung tao dun sa shop na pwede na daw stock tires ko. pero di ba mag mukhang parang /-\ ganyan ang tires kung stock rims use ko??
    summary: will my old 15" stockmag rubbers fit a new set of 15" offset mags?
    may rubbing kaya ...
    Nov 2019
    planning to buy enkei rpfi's for honda city 2016
    any advice what off set for flush fitment
    planning on 17's x 9's
    thanks
    new here
    Quote Originally Posted by jujangero View Post
    thanks
    new here
    You'll likely poke & rub w/ 9s. A higher offset might free your fenders, but unlikely your inner suspension. 8.5 wrapped w/ a stretched tire & some fender roll might get you there.
    The stock specs can take 17x7.5, et40, 225/40/17 or 205/45. Et35 might still work.
offset mags tires correlation?
