Results 1 to 10 of 13
- Dec 2004
- 20
December 15th, 2004 12:33 AM #1is 245/60 too big for xtrail? kase takot ko if nag 245/50 ako baka sobrang lakas yun road noise. gusto ko lang maporma without sacrificing much in terms of ride quality and noise level. pls help. and also ano mga ok na tires ngayon. i had experience with toyo proxes and lemans b4. thanks
December 15th, 2004 01:42 AM #2
I've seen 245s on an xtrail (try to search cardomain.com) but you might have to sacrifice your turning radius.
December 15th, 2004 10:36 AM #3
baka 225/55 ka lang dapat bro. malaki ang probability na sasabit sa kabig yan pag 245/60
- Dec 2004
- 20
December 15th, 2004 11:17 AM #4if 55 series malakas na ba road noise nun? or konti lng diff nya from stock na noise? thanks sa replies.
December 15th, 2004 12:08 PM #5
konti lang. and road noise would depend on the thread pattern also of the tire, not just the sidewall thickness.
- Feb 2005
- 6
February 11th, 2005 05:20 PM #6235/50R18 best fits your xtrail...i know, because i have them in my car(falken ze512). Smooth, quiet and comfortable ride...because its actually a passenger tire. just follow your recommended tire pressure located in the door panel, i think.
February 11th, 2005 05:54 PM #7
boothchokoy: how much for your rims and tires?
eksss: any pics of your ride?
- Feb 2005
- 6
February 12th, 2005 12:29 PM #8my mags cost around a 100k and tires for 26k. the tires you choose makes a big differences in terms of comfort ( if its made for off road use, then you will have a harder ride..because of the sidewall construction) but since you want a porma looks and ride and handling of a passenger car...then you should choose a passenger car tire. hope this helps...
- Aug 2004
- 17
