Results 1 to 6 of 6
    Jun 2012
    Help guys, san kaya ako makaka bili/kita ng original blackrhino sidewinder r20? For 2012 Montero
    Nagka crack kasi ung isang rim ko na nag ca cause ng leak ng tire pressure. May mabibili kaya akong 1 pc lang and nasa magkano kaya to? Ayoko na ipa repair since walang peace of mind. Either back to stock or hanap ng 1pc.
    Quote Originally Posted by mar04 View Post
    Width/PCD/et?
    Jun 2012
    Width/PCD/et?
    Sorry sir I'm not familiar with PCD/et. 265/50 r20
    Nov 2017
    for what vehicle ? most suvs should be 6*139.7
    navara and terra though uses 6*114.3
    Jun 2012
    Quote Originally Posted by LOLZ View Post
    2012 Montero
    Nov 2017
    2012 Montero
    should be PCD 6*139.7 for offset(et) sometimes they'll be sometimes stamped somewhere on the rim such as the inbetween the spokes atleast these were the case on stock toyota rims it'll look like 14*5 1/2JJ 27 for 14 inch dia 5.5 inch width 27 ET some will show et27 instead.You can measure ET manually as how far in/out the mounting surface from the center line of the rim and width from lip to lip of the rim
HELP: Looking for 1 pc ORIGINAL Blackrhino r20 Sidewinder
