Results 21 to 30 of 40
May 11th, 2010 01:40 AM #21
naku had that problem before. pinalitan yung pito, ganon pa rin. then yung dinala ko ulit sa ibang vulcanizing shop, binabad sa tubig then wala sila nakita bubbles AT FIRST. then after a few seconds na nakababad, yun na, meron maliliit na bubbles.
it came from the dirt in between the rim and rubber. so ginawa nila, kinaskas yung mga dumi then binalik ng walang grease. naging ok na.
May 11th, 2010 01:48 AM #22
Will try that sir. Thanks! Naku, kaya pala pati sa civic namin ganoon rin. Nung binalik yung gulong may grease eh. Makapal pa kasi yung goma kaya mahirap ibalik.
May 11th, 2010 01:54 AM #23
ok lang naman daw may grease kasi ganon daw normally ginagawa. kaso yung dati ko mags, kinapitan na daw ng husto kaya kinaskas. lalagyan dapat ulit ng grease tapos sabi kung pwede wag na lagyan. ayun nagOO, nahirapan ibalik yung goma.
May 11th, 2010 02:01 AM #24
Hehehe. Kapitin kasi ng dumi kapag greased eh. Parang tireblack lang, kapag oily/greasy, dumihin
- Sep 2004
- 17
June 6th, 2010 03:15 AM #25Hi!
I came here looking for a solution to my Good Year tire problem (front right tire, corolla gli '94). Makapal pa iyong gulong (2.5 years old). If I insert a coin in the thread, malalim parin. Tire never repaired.
Here is what has been done:
1. At first, palit pito.
2. Then sumingaw ulit after 2 days. 20 psi na lang.
3. Then balik sa vulcanizing shop. Overinflated the tire. Wala makitang butas kahit nakalublob na sa tubig. Although partially lang iniikot ung tire sa tubig na around 8 inches deep, not fully submerged. Then hiniga ung gulong, ung contact between tire and rim binuhusan ng tubig. Wala naman bubbles. So obserbahan ko daw. Eh after 2 days deflate na naman.
4. Lastly, I interchanged the mags with the one on the back. Inspected the inside of the tire, still smooth and no physical defects that can be seen. Same tire: Inflated at 31, after about 24 hours at carpark, 28psi nalang.
Inflated again at 33 psi today then pag uwi ko 28 psi nalang, it was a long 50km drive. Sumingaw na ulit.
The other tires still maintained their original pressures.
This is driving me nuts. San kaya maganda mag pacheck ng gulong. Sa Shell or Servitek ba fully submerged iyong tires when trouble shooting?
Effective ba talaga iyong pag brush sa rims? Previously, I have been using this mags on the back and the tire did not deflate.
I was thinking parang mas mabilis ma deflate pag ginamit ang kotse kesa iyong nakapark lang sya. What could be the problem.
Thanks for any suggestions...
June 6th, 2010 03:23 AM #26
had the same problem few year/s ago with our vios' front right tire. the first remedy was have it aligned. few weeks/months after, the problem occurs again. but that time, the 4 oem tires are due for replacements.
now with the new tires, the problem never occured again.
- Sep 2004
- 17
June 6th, 2010 04:10 AM #27Thanks aejhayl17 for the reply.
So if everything fails, it is wiser to replace the tire. Kaso makapal pa iyong sa front left, sayang din. Sabay sabay dapat palitan para pantay. Gastos na naman
I have read in the other thread that pwede daw lagyan ng interior ang tubeless tire, kaso kakatakot ata pag interior. Pag natusok, flat agad in a few minutes.
Then someone also said it could be micro pore holes. Hmmm... possible pala iyon sa tires?
June 6th, 2010 04:13 AM #28
Mas mabilis ma deflate iyong naka park lang sasakyan at hindi ginagamit. Iyong pag brush sa rim ginagamit at nilalagyan minsan ng langis para lumapat maigi ang rim sa gilid ng goma . Kung matagal bago mabawasan ng hangin may maliit na butas goma mo nangyari na rin sa akin na halos matagal ang interval ng bula pagnilubog sa tubig.
- Sep 2004
- 17
June 6th, 2010 04:30 AM #29*speed unlimited,
Thanks. Nilagyan naman ng langis ung rim bago binalik.
So kelangan sobrang tagal nakababad sa tubig then watch like an eagle. Ginawa narin namin sa shop, kaso after about 30 minutes, sumuko na iyong inspector...
- Sep 2004
- 17
Tesla Philippines
