Results 1 to 4 of 4
    May 2007
    Mga sir,
    ilan psi or specified fuel pressure po ng carens na 1.8 or 2.0l gas na carens.
    Para malaman ko po kung need ko kailangan magpalit ng fuel pump o hndi kc hndi na ung priginal pump ung nakakabit.
    Black smoke kc lumalabas na usok. Sabi ng ibang mechanic to much pressure kc minsan dahilan.
    Malakas sa gas ung oto ko nasa 5-6 km / liter ako.
    Thanks.
    Aug 2005
    IMHO, if you're car is a gas variant.. Baka hindi lang fuel filter ang kailangan mo check.. I would suggest bring it to a casa.
    Aug 2004
    Too much pressure? Not for an EFI engine. Not usually. It's more likely an issue with your sensors. The casa should be able to check for codes that will point out what's at fault.
    If you have no idling issues, then it could be an O2 sensor or MAF issue... or even a bad sparkplug.
    Quote Originally Posted by jm_splitfire View Post
    Mga sir,
    Thanks.
    sorry kung medyo ot: ask ko lang po.
    hindi po ba normal lang ang 5-6km/l sa 2.0 engine?
Kia carens 1.8 or 2.0 l gas dohc 16v specified fuel pressure ???
