Results 1 to 10 of 13
- Feb 2017
- 36
October 29th, 2017 07:04 PM #1Isuzu hilander 97 model
Newbie ako sa sasakyan kya ask ko po kng anu problema.
Nagpalit ako ng ilaw yung signal light n orange,nagkamli ako ng kabit,nashorted sya,
Ayaw na umilaw ng tail light at dashboard saka radio at clock wala n,kya hnd ko mgamit sa gabi pero yung head light nya ok,
Ncheck ko n fuse san b bnda ang iba png fuse nito bikod sa baba ng drivee side,
Hnd ko mkita kng saan busted.
Salamt sa mkakatulog
- 53,883
October 29th, 2017 07:10 PM #2if you can get a hold of an owner's manual.
usually, the manual has a diagram of the fuses and what appliances they control.
the combination of non-functionals above, suggests one or two fuses, that the manual should be able to point out.
a number of cars have two sets of fuseboxes. one in the engine bay, and another hiding under the dashboard.
if owner is lucky, the fusebox cover has enough diagrams to indicate which fuse is which.
otherwise, one will have to look for these diagrams.... from manuals or from internet downloads.Last edited by dr. d; October 29th, 2017 at 07:22 PM.
- Feb 2017
- 36
October 29th, 2017 07:26 PM #3
- Feb 2017
- 36
October 30th, 2017 09:22 AM #4Up ko lng po ito,san ba ang location ng isuzu hilander ang relay at fuse box bukod sa baba ng driver side?
Salamat.
- 53,883
- Feb 2017
- 36
October 30th, 2017 09:59 AM #6
October 30th, 2017 11:35 AM #7
I suggest that you just replace the fuse... (kahit sabi ng tester gumagana).
- Feb 2017
- 36
October 30th, 2017 11:48 AM #8
November 3rd, 2017 12:57 PM #9
may relay para sa park/panel lights sa bandang driver's side lower panel or cover. kasama sa panel/cover yung takip ng fuse holder, speaker grill at aircon vent.
pag tinanggal mo yung panel, may speaker dun. tanggalin mo yung speaker, naka screw lang un.
dun sa butas, makikita mo dalawang relay.
yung 2nd relay para sa park/panel lights. yung 1st para ata sa fog lamps.
naka clip un relay kaya ingat sa pagtanggal.
November 3rd, 2017 01:04 PM #10
Tesla Philippines
