Sir... Try to check your Center Link ..
Printable View
tnx sir red:happy:
2006 Crosswind XT LE with 36,000+ km....major part replaced (in terms of cost) is the fuel tank floater (4 thousand plus pesos).
helo po sa mga tsikoters.. pls help me po kung anu pwede gawin sa water separator ko.. nasira na po kasi ata sensor nya..gnwa naman namin lahat ng asa manual pati sabi ng casa palitan nalang.. san po kaya makakabili ng medyo abot kayang presyo nun or kaya mga 2nd hand nun..tnx po sa mga makaktulong...:happy:
04 croswind xuvi
53k mileage
prob. with speakers.. busted
brake pedal sticks.. when you brake.. it won't go up completely. maybe 10%.. so the light is always on.. discharged the batery.. just a quick fix after that..
Up lang po para mapost dito yung mga problems na naencounter natin.
Thanks.
...the problem i had with my 2010 sportivo mt as i had posted before on the previous threads was a leaking radiator, had it replaced at isuzu since it's still under warranty. then some minor paint peeling on the side panels and a corroded differential, again rectified by isuzu. and lastly, the indicator lights(oil, battery, etc.) goes up whenever i go through flooded streets which the people at isuzu explained that it was just a slip of the fan belt when it gets wet....
'01 XTO: 158+++ kms
last year replaced: oem centerlink, oem clutch master, oem ball joints, oem bushings, oem front shocks, oem foglamp bulbs
this year replaced: oem clutch and clutch related thingys, oem belts, and had my radiator's leak repaired at DANTE's RADIATOR SHOP a. bonifacio. mababait na mga tao at mahuhusay!
my ride's second hand when i bought it years ago, kinulit ko pa ng kinulit yung dating may-ari para ibenta. after all the years and kms it served, halos ngayon lang bumigay yung mga namention ko.
So Isuzu have not yet addressed this problem of leaking radiator. Mine was replaced on the first year of my ride, 2010. Good thing is that the original radiator was still given to me after replacement, so I always have a spare and it's always a recurring problem yearly maybe because of the engine vibration, but then I was able to live with it.
Double post, sorry.:grin:
