Page 126 of 145 FirstFirst ... 2676116122123124125126127128129130136 ... LastLast
Results 1,251 to 1,260 of 1445
    Feb 2011
    #1251
    Quote Originally Posted by leirariel View Post
    * Sir Jhun
    I have been inactive for so long. Super busy kasi. It feels good to be back and back-reading previous posts. Anyway, I was just wondering why you paid 5k+ when Isuzu Pampanga replaced your TPS? I had mine replaced by the same casa last April for 0 pesos.
    I had the same "check engine" problem. Though I experienced it one time only, I still took the Trooper there since it was included in their recall campaign. But it was for free.
    I am still very happy with my Trooper. It is still cooperating and behaving. No problems so far. Hope it keeps it that way.
    Hi sir leirariel;2231956, They replaced the harness for free but for the sensor have to pay for it, hindi daw sya free, good for you sir you got it free.
    Sep 2013
    #1252
    Good am sir's, we have Isuzu Trooper 2003 skyroof edition, casa maintained, pero may problema about injectors. Napalitan na ung fuel inkectors before when Isuzu recalled all Trooper Models, way back 2008 pero nasira na ulet this year. Anyone knows or can refer a mechanic specializing with Isuzu Trooper engines? any suggestions? please txt me nalang Jude-09178248221
    Nov 2011
    #1253
    Quote Originally Posted by jdyboy View Post
    suggestion: use clean diesel only (the expensive premium ones), because troopers injector was designed to be used in japan where diesel is clean... diesel in the phil is dirty because majority of the users are old diesel engine (trucks and jeepneys)
    Apr 2008
    #1254
    Diagnosed na ng casa na sira na ulit ang injectors? Have you tried EGR cleaning first? Also as mentioned, fuel quality is very important. I'd recommend Unioil's Euro 4 diesel.
    Sent from my GT-I9100 using Tapatalk 2
    #1255
    Sabi ng mechanic sa casa dapat daw regularly change fuel filter para maiwasan any pagkasira ng injector pati narin linis intake and egr para do agad masira tps
    #1256
    Sir paano nalaman sira injector?nag tech ba Sila? Ano symptoms?
    Feb 2005
    #1257
    Quote Originally Posted by dh0n View Post
    My Trooper underwent 2 complete injector replacement -- which included RPS, RPCV and TPS relays (these conidered to be maintenance items and may be replaced in the future -- of course, on the account of the owner )
    Based on my experience, there were variable symptoms depending on the suggestive extent to replace 1 or 2 or 3 or all 4 injectors (note that injector can be replaced individually and not necessarily altogether). Some I notice were the erratic idling (you see the RPM needle play), power lose (some consider limp mode), hard starting (which should not be overdone or the starter may get damaged and battery be drained/damaged) to name a few.
    But there is no best way to confirm what the problem may be without the Tech 2 gadget. That way, the Isuzu-trained technician would be able to pinpoint the culprit.
    #1258
    Quote Originally Posted by Benzmizer View Post
    Sad to hear that sir but still.do no pa binebenta trooper mo...un as amin till now fingers cross sana do muna bumigay injector(pinalit nung recall) and tps...nagpalit na ako ng rps rpcv once palang...timing belt nagpalit na nung 160+++km but not the tensioner....
    Sir pa OT yung remote ng alarm may Alam kabang makukuhanan? Or kahit yun shell lang Order basis as inteco pampanga Pero mukhang walang dumarating....TIA
    Apr 2013
    #1259
    Just want to share my bad experience with Isuzu Makati! Last Aug. 24 I went there to have my trooper checked using tech 2 and by the technician. Nagbabawas kse radiator coolant every now and then. Iniwan ko sya sabi kse ng tech na nakausap ko (Arnel ata name nya) balikan ko na lang dw mga around 4 pero tatawagan nya muna ako. Then naghintay ako ng tawag nya nung hapon kse ayw kong iwanan yung trooper dun ng matagal since saturday yun tapos sa monday holiday. Nung nakausap ko sya, sabi ok naman daw trooper. Normal lang daw mga gsto ko ipacheck. E di pinuntahan ko na. Nung dumating ako, ala na sya nakaalis na daw pero binayaran ko rin yung 990 pesos para sa tech 2 and yung inspection fee. Then nung nabayaran ko na, hinanap ko yung print out ng result ng tech 2 para maitago ko for reference sa future. Ang sabi nung isa, ala daw iniwan sa kanya si Arnel tawag na lang daw ako sa tuesday. Nung tumawag ako nung tuesday, ala daw print out kse ok naman daw. Ang sabi ko, dapat meron yun kahit may problema or wala yung trooper. Tapos dun na sya umamin na hndi daw na tech 2 yung trooper kse linabas daw sa casa yung machine!
    Sobrang hassle ginawa nila. Gusto nila ibalik ko daw uli sa knila yung trooper para i tech 2 for free! Ngayon, mahirap na talaga magtiwala kahit sa Casa!
    Sep 2013
    #1260
    Dinala namin s kasa tapos inasses nila, ewan ko lang kung accurate assesment nila, pero siguro tama naman. Ang suggestion nila is replace fuel injectos, along with other work p daw.
Isuzu Trooper discussion
