Results 1,011 to 1,020 of 1445
- Aug 2009
- 420
March 11th, 2012 07:42 PM #1011What should I do?
I am driving an Isuzu Trooper, 2002, local model. Upon starting the engine, the "handbrake" & "battery" signs lit up. When I released the hand brake, the "handbrake" & "battery" signs will dim but not totally off. I have checked the brake fluid and it’s ok. I can still drive the trooper with no problems.
- Nov 2010
- 236
March 12th, 2012 12:38 AM #1012
- Apr 2008
- 6,235
March 12th, 2012 11:58 AM #1013Hello there guys! Can you share as to where in Metro Manila magaling magcheck ng emission problems ng Trooper? Yung binenta namin sa family friend namin grabe umusok. Using V-Power diesel somewhat reduces that pero matindi parin. He uses Besco 10W30 as recommended by Isuzu and the filters are already all replaced/cleaned. Allergic siya sa casa kasi grabeng tumaga. So far suspects seem to be the EGR, oxygen sensor and the like. Saan kaya mahahanap ang magaling jan? Patulong naman bros!
- Aug 2009
- 420
March 12th, 2012 06:14 PM #1014
- Aug 2009
- 420
March 12th, 2012 09:56 PM #1015additional queries. alternator problem. if bago start ko ung trooper. iilaw ung handbrke, oil sign, check engine and battery. then when i start, maiiwan ung handbrake at battery signal. then when i release the handbrake, mag didim konti ang handbrake at battery light? electrical wiring problem? pls help
- Aug 2009
- 420
March 12th, 2012 09:57 PM #1016
- Nov 2010
- 236
March 13th, 2012 09:18 PM #1017sir its better to check your alternator first...anong ginawa sa alternator mo anong rinepair?...pansinin murin yung battery voltage gauge mo kung ano ang reading nung nagkaproblem ang sa akin the reading is below 10amps together with light battery indicator and hand brake light...
- Aug 2009
- 420
March 14th, 2012 01:17 AM #1018
- Aug 2009
- 420
March 14th, 2012 01:22 AM #1019
- Nov 2011
- 3
March 14th, 2012 01:27 AM #1020yeah mahal yung set ng injector.. almost 80k. nabili namin yung 4jg2 85k with transmission.. sure fresh from japan, kasi friend namin yung importer. no problem with the mounting, kasi as per sa friend namin from isuzu, parehas lang ang mount ng 4jx1 at 4jg2. im planning to change only the engine. may nakausap ako sa may banawe na, pwede daw gamitin yung 4jx1 na transmission sa 4jg2. electrical works? as per checking, heater and rpm lang yung kakapain. madami na din daw nagpapalit sa banawe from 4jx1 to 4jg2. sana mag work. good luck to us. pag naging success, i post our experiment and experience.
