Results 1 to 3 of 3
- Apr 2008
- 1
April 8th, 2008 02:40 PM #1ask ko lang po kung talga bang madalas mag over heat ung isuzu trooper 98
model xe po 2nd hand lang smen? pinacheck nanamen pro ders no leak nmn sa radiator..help nmn po!!!!! tnx!!!Last edited by Memphis Raines; April 8th, 2008 at 03:11 PM.
April 8th, 2008 03:27 PM #2
Welcome po to Tsikot.com!
Normally wala namang overheating problems ang '98 Trooper. A radiator with no leaks doesn't mean that there are no clogs in the fluid flow system ng radiator. This also includes the thick rubber hoses that connect the radiator to the engine and vice versa. One way to check if there are clogs is that madaling mapuno ang radiator ng water or coolant compared to the normal consumed level.
Yung ideal coolant consumption level can be found sa manual po. I think it states there how much is the expected volume of water/coolant.
Also you can check out this forum for more knowledge about radiators and cooling systems as a whole: http://tsikot.yehey.com/forums/forumdisplay.php?f=143
re Forum Posts:
Also as a reminder of the rules in posting, you are encouraged not to use 'text speak' here in the forums as this is prohibited. We can all also understand your queries better this way
- 6
April 8th, 2008 04:25 PM #3Try to check yung radiator fan mo or engine fan, kasi baka natuyuan na or naubos yung silicon oil sa loob ng pinagkakabitan ng fan. May silicon oil yun sa loob, check mo kung malambot pag-inikot mo lang ng kamay mo, kasi kialangan medyo maitagas yung fan kapag inikot mo using your hands un ang indication pag ok pa yung silicon oil mo sa fan. kapag malambot, ibig sabihin kulang o paubos na yung silicon oil nya, ang mangyayari kapag ganun, kapag umandar yung engine mo at nag-rev ka di sya sumasabay sa takbo ng engine, meaning mahina ang suction nya ng hangin para i-cooldown ang radiator mo... talagang iinit yan at magca-cause ng OVERHEAT. Mura lang naman yung silicon oil. Try to check your engine/radiator fan kung ok sya.... HOPE IT WILL HELP YOUR TROOPERS OVERHEATING PROBLEM..... balitaan mo naman ako if ever... THANKS!
Tesla Philippines
