Results 1 to 10 of 19
- Oct 2004
- 7
August 24th, 2010 09:15 PM #1Isuzu Hi-Lander owner's ...Yung indicator light ng water separator sa Isuzu Hi-lander ko, lagi naka -on kahit nadrain ko na ang water separator at fuel filter. Pinalinis ko pa ang fuel-water separator pero ganun pa rin, san kaya problem? Sira kaya ang separator sensor? If ever magkano kaya ang fuel-water separator? Thanks for any advice you can give me..
- Oct 2004
- 7
August 24th, 2010 09:30 PM #3You mean yung electrical line? ano'ng cluster, sorry for my ignorance..
- Oct 2004
- 7
August 24th, 2010 09:33 PM #4
August 24th, 2010 10:00 PM #5
If your gonna change your water separator have the pump checked as well. If its broken already might as well change the whole assembly. tip= pwede palitan yung assembly ng water separator & fuel filter na pang mitsu L300 mitsu, yun ang ginawa ko para mas maluwag yung compartment natin. Try pulling the elec. plug to check if grounded yung line. pag na bunot yun dapat mamatay yung light sa dashboard. If not electrical nga...
August 24th, 2010 10:04 PM #6
- Oct 2004
- 7
August 24th, 2010 11:06 PM #7Thanks blue_gambit. I already tried disconnecting the plug, patay nga indicator light pag nakakalag yun, that means di naman shorted. I'm confused with the "pump" you are saying. do you mean the top metal portion of water separator that is pump manually or iba pang pump? Yun ba plastic portion where drain plug is and the wire is connected ay nabibili ba separately or isang assembly yun? I'll try to see the L300 assembly, mas mura ba sya?
Sorry sa mga tanong, di ko kasi kabisado ang diesel.
August 24th, 2010 11:23 PM #8
Yup yun ang manual pump, sa hi-lander kasi mag ka hiwalay ang water separator & pump from the fuel filter. sa L300 mag kasama silang lahat. Got mine 800 bucks a few years ago, never had any problems kahit taiwan made sya. And it free'd up space sa section na yun na masikip before. I think assembly na yun siguro, ask walco (02) 7110277 sa banaue baka meron sila dun nung dulo lang. Hope this helps
- Oct 2004
- 7
August 25th, 2010 08:19 PM #10
Tesla Philippines
