Results 1,071 to 1,080 of 3710
March 14th, 2011 07:44 AM #1071
March 14th, 2011 11:30 AM #1072
mga sir, bro, at paps, may problem sa electrical ng ride ko, recently naka ilang beses nko nagpalit ng fuse sa headlight and foglamps laging busted then napansin ko pag nka idle ang engine medyo nahina ung discharge ng headlight, pag nag rev ako naliwanag sya ulit... may nabasa ko d2 s thread bout grounding kit,, un b kaya ang solution?????... BTW, naka ordinary all weather bulb headlight and na 100/90w - 145/125w....
P.S. ano ano ba advantages ng grounding kit????
TIA,, TIA,,,
March 14th, 2011 12:24 PM #1073
- Aug 2009
- 349
March 14th, 2011 01:12 PM #1074
March 14th, 2011 01:22 PM #1075
March 14th, 2011 02:32 PM #1076
Installing a grounding kit is a safe and reliable way of creating a low resistance ground path for your car. The kit provides direct ground paths from battery negative to body, chassis, and specific engine components to give a noticeable improvement in electrical circulation. Reduced electrical “noise” can improve ECU signals and throttle response resulting in better performance and reduction in flat spots, and many more benefits associated with improved grounding.
This also prolong bulbs, same as what I am experiencing now with my Trooper.
Standard feature beginning 2011 XT.
- May 2010
- 48
March 14th, 2011 06:02 PM #1077yung ibang nakikita ko sir pininturahan lang nila ng epoxy based paint yung under chassis nila.. dunno kung effective sa ride natin yun.. pero sa mga ot jeep ok naman ganun kc ginawa namin nun sa otj namin.. iniisip ko nga din na ganun nlang gawin ko nababakbak na kc yung under coating.. ok ba yun mga paps
- Mar 2011
- 13
March 14th, 2011 06:04 PM #1078Hi Guys, Im new here. Ask ko lang ano recommended engine oil nyo. I owned XTO 2001 model. thanks in advance.
March 14th, 2011 08:13 PM #1080
