Results 11 to 20 of 22
    May 2017
    UPDATE: Apparently it was a faulty VacSwitch, they replaced it for around 4k. Seems to be working just fine as of the moment.
    Jun 2017
    Did anyone try to get the error codes so that mas accurate yung diagnosis ng trouble?
    Dec 2016
    good evening mga sir! i also experienced an issue regarding po sa check engine ng dmax ko. when i reached 100kph, check engine light is on. then once na pinatay mo yung makina, mawawala po sya. den when u reach again 100kph, iilaw po ulit yung check engine nya. but the rpm is stable naman. anyone who can help me po mga sir? thank you in advance!
    btw, dmax 2007 4x2 model po siya. 4jh1 engine.
    Sent from my SM-J710GN using Tsikot Forums mobile app
    Dec 2016
    Sir na-solve nyo na po ba itong problem na ito? This is also happening on my dmax right now. May I know po kung ano po yung gnwa nyo para masolve? Galing narin ako sa isuzu unfortunately di kasi available ung scanner nila ngayon. Same problem lang po tayo sir kaso 100kph ung start nung akin. Thanks in advance sir!
    Quote Originally Posted by lraklee View Post
    i have this issue also DMAx 2005 MODEL, when i reached 110kph CHECK ENGINE LIGHT appeared, pero ok naman takbo di bumabagsak RPM, ang ginagawa ko po off engine then on uli tapos wala na, kapag tinakbo ko uli ng 110+ kph CHECK ENGINE again. Ano po kaya problema ng ganito? salamat
    ^ Check mo yun air cleaner at MAF. Ganito issue nung service dmax ko, linis lang.
    Dec 2016
    sir ano po yung MAF?
    Sep 2017
    Quote Originally Posted by Daryljake View Post
    Mas mainam mga sirs ipa scan ninyo....
    as per my experience faulty po ang VSS..(VEHICLE SPEED SENSOR)pag ganyan ang symptoms.
    hope it will helps.
    Best regards,
    AIS
    May 2012
    yesterday I experienced po nawalan ng hatak yung Alterra 07 MT then few minutes later umilaw po check engine, then nagtry ako on and off ng engine di po nawala, then pinagpahinga ko ng mga 3hours then start ulit nawala naman sya, hanggang ngayon drive ko ng 25km papunta sa office d na po umilaw check engine? any idea guys, first time po nangyari
    May 2012
    Quote Originally Posted by metal_mulisha01 View Post
    update lang:
    umulit yung problem ko masmalala na, di ako makalampas ng 2K rpm so dinala ko po sa ISUZU Batangas (Sto. Tomas), replaced SCV (P7.6K) so far naman ok na ngayon, still under observation... as per SA modified na daw yung naka install masmahaba.
    Dec 2016
    Quote Originally Posted by AIS View Post
    hope it will helps.
    Best regards,
    AIS
    sir pina scan ko na po sa isuzu. kaso wala naman po maread na issue ung scanner.
DMax Check Engine MIL
