Results 11 to 20 of 23
    Nov 2014
    Quote Originally Posted by xwind_mariner View Post
    Check, inspect the quality of fluid and if color/smell like burnt, replace the fluid.
    Thanks for the advice. I will try to clean first the filter then change fluid. I have this delayed reverse for the past 6 months now and it's not getting worse naman.
    Jan 2014
    Change ATF regularly 20k kms
    kick-down cable pwede maputol so have it checked too
    And radiator is supposed to be designed for A/t models because it also cools the ATF
    I owned and driven a 2003 XUV A/T acceleration is okay not really much difference with my stick shift innova pero mas masarap ihataw yung innova heheh.
    Eka nga walang mabagal na sasakyan kung magaling ang driver hahah.
    regarding sa usok ihose mo lang ung exhaust every weel. Sa ASBU nver pa ako nahuli for 13years of living in and driving around makati.
    Jul 2015
    hello po sir... try mo po change oil ang at transmission nia patangal mo oil pan nia and may strainer po yan sa baba ipa cleaning mo po yan and yung tubes babaklasin nila yan at hahangainan ng compressor. it should have no delay na yan update me po sir tnx
    Jul 2014
    Sir tanong lang kung 43LE o A340E ba mga gear na nakakabit sa mga crosswind na AT?
    Nov 2014
    Quote Originally Posted by mrjeff View Post
    03-72LE Aisin Warner
    Nov 2014
    Quote Originally Posted by qccrosswind View Post
    Done changing fluid, cleaning strainer at nilagyan ko pa nang Mag1 stop leak additive. There's little improvement po from 10 sec to 5 sec delay sa reverse. Sa D, L2 and L walang problema. Shifting is very smooth.
    Jul 2014
    Thanks sir sa info.
    wow... 5 second delay... never had this problem on a 2000 pajero. mine isuzu is a m/t. problem KO lang, Mahal mag maintenance sa casa. kahit, old school engine.
    Quote Originally Posted by crosswind View Post
    paano bos mag-hose down ng exhaust ng isang diesel vehicle. gusto ko sana i-try sa monty namin
    Quote Originally Posted by kevinworld View Post
    a 5 second delay for me would be a source of concern. hopefully, maayos iyan bos
    btw, may accompanying sound or shift shock ba pag nag engage na iyong reverse?
    Nov 2014
    Boss, walang sound at shift shock pag ni reverse ko. Very smooth pag nag engage na. Sana it will not get worse. 5 sec delay para sa akin is acceptable kasi nang yari lang yon during cold start in the morning.
Crosswind XUV Automatic (AT) Transmission
