Results 1 to 10 of 12
- May 2011
- 6
September 20th, 2011 08:57 PM #1I own 2005 dmax ls and am experiencing problems na. My check engine indicator turns on then I lose power. Sabi sa casa change oil, change air filter, change ko din ang fuel filter but bumabalik parin ang CHECK ENGINE.. What will I do?
September 21st, 2011 01:26 AM #3
Good day to all Troopers,
My check engine light come and go for the second time, it's trooper 2002 LS. is this sign as early warning for an oil change?, trooper is nearly reaching the 5k interval, any inputs are highly appreciate, thanks.
- May 2011
- 6
- Mar 2004
- 434
September 29th, 2011 08:24 AM #5*ts- i own a 2008 dmax. i had that too 2 weeks ago. what i did was drain the fuel from the water seperator valve at the hood. did it a few times.
everything is fine now.
by the way. another symptom. if in the morning you start your engine and you hear a clatter in the engine before it runs fine in warmup then there is air in your fuel system. and so bleeding it is what made my dmax run fine.
hope this helps.
- Mar 2004
- 434
October 28th, 2011 08:17 AM #6update on this problem with check engine light and losing power. just sent my dmax yesterday to the casa. and the tech2 reported problem with the SCV/ suction control valve. replacement for the "modified" scv is P7990 ouch.
- Jan 2008
- 4,726
October 28th, 2011 09:15 AM #7nyek... parang din palang D4D yan Dmax... SCV din ang problem.... Denso system ba yan?? papalitan mo na
- Mar 2004
- 434
October 28th, 2011 08:16 PM #8
- May 2017
- 1
May 6th, 2017 07:43 PM #9
May 6th, 2017 07:52 PM #10
common? first time seeing it... so its not common...
Tesla Philippines
