Results 1 to 10 of 10
- Apr 2010
- 7
July 8th, 2012 01:17 PM #1Good day.
Hingi po ako suggestion, what is the best engine oil for my 2009 Isuzu Sportivo Crosswind. Malapit na ksi PMS-30,000 Km. Many Thanks.
July 8th, 2012 01:41 PM #2
There are a lot of options. Depending on your budget.
- Apr 2010
- 7
July 8th, 2012 07:48 PM #3Ok, ganun po ba, please give me options from the chepeast, average, to most expensive. Thanks.
July 8th, 2012 07:57 PM #4
isuzu rizal uses shell rimula diesel 15w40 on our crosswind so i guess this is a good choice.. yung 4ja1 engine hindi naman maselan sa langis as long as regular ang change oil and within manufacturer's specifications ang gagamiting langis
July 8th, 2012 07:59 PM #5
Well there's delo400, top1 sdo, zic up, mobil tdt, royal purple.
July 11th, 2012 08:25 PM #7
Mga paps ask ko lang kong ano talaga ang tama sa pag check ng engine oil sa deep stick di ko alam kong nasubrahan ang pagkalagay ko o tama lang. a.) pag di umaandar sasakyan with in 2 to 3 days tapos tsinek ko lagpas lagpas talaga sa high level.
b.) pag pinaandar ko naman din check lagpas lagpas naman sa minimum. c.) ano ang tamang pag check BEFORE or AFTER engine running? Thanks in advance.
- Aug 2013
- 1
August 2nd, 2013 12:59 AM #8In my own experience for almost 17 years of dealing with diesel engines,although not car engines but
for marine diesel engine applications, 15W-40 an multigrade diesel engine oil.15w means is for lower climate country.The temperature at which oil can still flow. Number 40 also means for temperature and this is suitable for tropical country.I suggest 15W-40 is good for isuzu sportivo.
- Jul 2008
- 398
August 2nd, 2013 12:29 PM #9also changed my oil 3days ago. kulang budget ko sa shell hx7. so, hx5 nalang plus vic filter. cleaned also the air filter. medyo smoother after getting fresh oil
- Jun 2014
- 3
June 30th, 2014 10:08 PM #10sirs,
mga ilang litro ang kailangang engine oil para sa sportivo?
pareho ba ang oil filter, fuel filter, at air filter ng sportivo sa crosswind xt (2004)?
balak ko sana bumili sa auto shop.
malaki kasi patong ng mga piyesa / lube sa gas stations.
nagmahal pa ang delata.
Tesla Philippines
