Page 1016 of 1213 FirstFirst ... 9169661006101210131014101510161017101810191020102610661116 ... LastLast
Results 10,151 to 10,160 of 12125
    Jan 2008
    #10151
    Quote Originally Posted by Rob*143 View Post
    Sa mga nag palit ng wiper what brand and how much yung wiper? My ride is LSA-MT acquired June 2016 with 19.6k sa odo. Tnx much.
    Sent from my ASUS_T00J using Tsikot Forums mobile app
    Nwb design wipers un ipinalit, I think 2mos old pa lang nagpalit na ko kasi napapangitan ako sa stock wiper blades, ipinasa ko na lang sa pickup ng tatay ko. Sa rear, nwb gra type naman ang pede, pero di pa ko nagpapalit
    Sent from my R7plusf using Tapatalk
    Oct 2016
    #10152
    Hi mga sir, normal lg ba marinig yung clamping of gears when shifting sequence of reverse and drive? Ls-a 3.0 unit ko, wala nman problema sa pagtakbo...13000 na odo ng unit, first car ko kasi to pero bihira ko lg ma drive dhil sa abroad work ko kaya no idea ako kung normal lg ba to sa automatic tranny, sabi ni misis since daw pagkuha ganyan na at normal lg daw sabi ng casa, please advise mga sirs...ty
    Sent from my ASUS_Z011D using Tsikot Forums mobile app
    hindi patag siguro ang parking... some AT have this issue. even the new fort has this. and the fort guys have a sequence how to avoid it.
    Oct 2016
    #10154
    Kahit patag po parking at talagang we make sure na nag totally stop ang car bago mag change gear...anu po sequence they use to avoid? Plan ko rin dalhin sa casa d next ff days pag d na busy...thanks po
    Sep 2008
    #10155
    Hindi na ako maka-mirror ng screen sa HU using my iPhone after updating to iOS10. I was able to before the update (LS-A/AT 2016)
    Meron po ba kayong similar experience? We're you able to solve it? I hope you can share how.
    TIA
    Oct 2005
    #10156
    Quote Originally Posted by Aceboy View Post
    may 15° slope sa kalye sa harap ng garahe namin. eto po ginagawa kung mag-park sa kalye:
    1. full stop,
    2. with foot on brake, shift to N,
    3. pull hand brake until engaged,
    4. slowly release foot brake,
    5. if mux rolls forth or back, full step on foot brake,
    6. pull hand brake one or two notches, as possible,
    7. slowly release foot brake,
    8. repeat steps 5 to 7 as necessary until mux stays put after step 7,
    9. shift to P.
    pa-correct na lang po kung kulang o sobra. hope this helps...
    #10157
    step on brake until full stop.
    N.
    pull handbrake.
    release foot brake.
    if still moves, pull additional 1 or 2 clicks on handbrake, until stop moving.
    put to P. you know you have to put to P, if you want to pull out your key.
    you can vary the steps. the end is the same.
    i have a couple of dos por doses in the trunk, justin case... (wheel wedges!)
    Aug 2009
    #10158
    Simula nung pinalitan ng gear oil yung unit namin nung 1.5k PMS ganyan na din symptom.
    Dapat ata maghanap ng mas malambot na gear oil para mawala yan.
    Quote Originally Posted by Sleepcare View Post
    baka ibang gear oil gamit. ginamit nila gear oil for the trucks..
    Jan 2008
    #10160
    Nakalagay naman sa manual na pede ang sae 90 o sae 140 gL5 type gear oil. Pero recommended un 85w-140 gL5. Un ang ipinalit ko, delo brand, hirap lang maghanap, nakahanap nga ko pero 1pail naman, naghanap na lang ako ng mga kahati
All New Isuzu MU-X // Alterra Next Generation
