Results 141 to 150 of 210
August 29th, 2010 12:21 AM #141
- Aug 2010
- 8
August 30th, 2010 01:02 AM #142Hi!
I'm just new here in Tsikot! I just want to ask if what's the best to use for change oil for Isuzu Trooper '03, 3.0L, AT. Last change oil ko kasi was in Shell-Timog.
Another concern ko is that pag narddrive ako and umaabot speed ko ng 110-130km/h is it normal na magzero (0) yung oil guage ko? pls give advice.
Thanks a lot Tsikoters!
August 30th, 2010 09:24 AM #143
No, it's not normal. What kind of oil (particularly the viscosity rating) are you using? I would suggest that you bring it to a CASA or reputable shop with Tech2 gadget to determine what is causing that faulty reading in your oil gauge. Could be a case of a shot or defective relay or sensor.... but it's difficult to self medicate. Tech2 would confirm that.
My 2 cents.
- Jun 2008
- 54
August 30th, 2010 02:10 PM #144Though Isuzu stopped the production of their trooper line, are they still producing parts for the trooper line?
are parts for the trooper (4jx1 or 4jg2) still very much available in the market? (e.g. casa or auto shops)
Thanks!
August 30th, 2010 07:41 PM #145
August 30th, 2010 11:01 PM #146
- Aug 2010
- 8
August 31st, 2010 01:38 PM #147
August 31st, 2010 03:14 PM #148
Yes I do. A 2005. I had experienced a similar case before. Had Tech2 run it and saw that the sensor was shot. Had it replaced.
To be accurate about it, bring it sa CASA na lang. That's what I did. I don't think naman the CASA would charge you much if you let them run the Tech2 on your Trooper.
- Jun 2008
- 9
August 31st, 2010 08:59 PM #149My '02 Isuzu Trooper (mileage 58K) stalled yesterday while I was driving. I was able to restart the car and run it (it was a slow crawl) til I reach a safe place to park it. There was black smoke coming out from the exhaust everytime I hit the accelerator. After that it won't start already. Initial diagnosis by the mechanic is that the oil is mixing with the fuel (dreaded injector problem). I guess I am the latest victim of the 4jx1 problem.
Several years ago, I contacted the Isuzu dealership to inquire about the recall, whether my car was subject to it. They said that my VIN was not included in the recall and that only models 2003 up were part of the recall. My question is if the fault of my car is due to the 4jx1 problem, can I ask for free replacement of the injector? To thos who had their injectors replaced: is it better to sell this car then keeping it and incur repairs in the future?
August 31st, 2010 09:37 PM #150
kewl_head,
i think that's injector problem... That was also mentioned by SA when I brought my 2003 Trooper during 60KM PMS. So, they replaced the O-ring & charge me less than 2K including the labor. I think this is also part of the silent recall. Prior to that, I always mentioning this to them to replace the o-ring due to excessive smoke on my trooper. At last, during the 60Km check, they replaced it. As of now, my trooper is * 88Km & doing fine.
Are you the 1st owner? Did you regularly send your trooper for PMS in the casa where you bought your trooper? I think you can still ask for a recall...it is not based on the year but based on the engine 4jx1.
...also,my trooper is casa maintained & have been using multi-z 10w30 engine oil.
