Results 1 to 10 of 19
    [SIZE="4"]REMINDER: do not post in SMS/TXT shortcut format.
    Read the rules.
    Ignorance of the rules is not an excuse.
    Repeated offenses will lead to banning.
    [/SIZE]
    The problems sounds like the engine going into "safe-mode".
    Maybe a fueling problem?
    Injectors or fuel filter condition?
    Oct 2008
    The problems sounds like the engine going into "safe-mode". manual trans?
    thank you sir sa information. advise ko sa kanila, parang di nila alam yung problem
    Jul 2010
    Sir i suggest ibalik mo sa casa na binilan mo kasi under warranty pa siya and let them solve the problem
    try nyo po yung fuel filter.
    dati sa nanay ko starex crdi gradual loss of power hanggan namamatay na makina ng tuluyan. after a minute or two of waiting aandar nanaman sya uli only to repeat the entire cycle again after just a few kms.
    it was contaminated fuel resulting to a clogged fuel filter so after 2,000 plus pesos, a new filter and draining the fuel tank ayos na uli sya. hth
    p.s. binasa ko po uli yung symptoms. try nyo din pa-check yung variable geometry vanes ng turbo baka for some reason di bumubukas consistently kaya may loss of power po kayo
    try the fuel filter. what is your mileage now? i plumb forgot to replace mine after over 39K. my engine would cut off when i tried to rev her..
    Oct 2008
    sorry , edit ko na
need help starex crdi 08 lost power
