Results 1 to 10 of 4790
- Sep 2013
- 168
October 10th, 2013 12:14 PM #1Not sure kung ganito rin ang hitsura ng indicator lamp sa Accent HB. Pero if it bypasses the starter circuit while activated, then the engineers at Hyundai did a pretty good job. It's normal and should be the correct process IMO. Diesel yan eh,
- Jun 2013
- 38
October 10th, 2013 05:20 PM #2*kompressor yup ganyan nga but nasa lower left ang glow plug indicator.ng hatchback.
- Jun 2004
- 48
October 11th, 2013 11:37 AM #3Is the glow plug indicator supposed to come on? First time with a Diesel and it doesn't come on on my unit even at cold start.
I also noticed that I have a P0381 OBD error (Glow Plug/Heater Indicator Circuit Malfunction). It's been there since I got my Accent which I thought was normal.
- Sep 2013
- 168
October 11th, 2013 12:11 PM #4
- Jun 2004
- 48
October 11th, 2013 02:46 PM #5
- Sep 2013
- 168
October 11th, 2013 03:12 PM #6
- Jun 2004
- 48
October 11th, 2013 03:47 PM #7
- Jun 2013
- 38
October 12th, 2013 07:06 AM #8Yup it should come on when you put it on Acc as it is an important part of a diesel engine before starting although mine only lights up for a second then im good to go lol. If there was an error since you got the unit you should have already asked them. It may have other complications if you dont get it fixed. Its always better to get it checked right away especially if the concern is engine related. just my 2 cents
- Jun 2011
- 181
October 12th, 2013 09:39 AM #9same with mine sir, pag on iilaw ng about a second then good to go na, kahit malamig yung weather hehe. dati hinahanap ko glow indicator d ko makita, ginawa ko pag on wait na lang ako ng 5 seconds or so bago start hehe. andito pala sa lower left part ng gauge yung glow indicator lagi ko pa naman hinahanap sa gitna kaya d ko nakita agad nyahahaha.
October 10th, 2013 07:45 PM #10
Yes the glow plug indicator light is off when it happend. 2 seconds lang usually on yung light indicator before it turns off. The longest non cranking I recorded was around 10 seconds before the engine crank to life. Will have it check na lang siguro. It could be the bypass circuit on the glowplug having problems or defective. Akala nya on pa yung glow plug but off na pala.. Will update this post on any findings..
Tesla Philippines
