Results 1 to 10 of 22
- Aug 2012
- 15
August 6th, 2012 05:51 PM #1Hello po mga tsikoteers.
May question lang po ako regarding sa quality ng engine oil for accent crdi.
Base po kasi sa nakalagay sa manual, ang required na engine oil quality is at least API CH-4 or ACEA B4
So naghanap po kami ng engine oil na may ganyan specs, ang nakita ko lang po na available that time is Kixx Turbo RV (API CI-4, ACEA A3/B4).
Ang price po ng kixx is 1700 for 6 liters sa banawe.
Medyo pricey nga po compare sa regular diesel oil.
Sa mga owner ng accent crdi, anong engine oil po ang gamit nyo?
Sinusunod nyo din ba yung engine oil requirements ng manual?
Ok lang din ba na ang gamitin na oil is regular API CF-4 tulad ng Shell helix hx5?
May magiging problem ba sa engine kung regular oil lang ang gamit?
Balak din po kasi na gawing taxi yung accent namin.
So i just want to make sure na it wont affect the engine kung sakaling regular oil lang ang gagamitin namin for business.
Sa mga tsikoteers na may taxi business, any kind of advise po would be appreciated.
Thanks po in advance!
August 6th, 2012 06:13 PM #2
better follow the API rating. madami naman na CH-4 or above na oil. and reason kung bakit kailangan ng CH-4 or above is becuase of the EGR valve. and using of better oil will prolong the turbo life. please correct me if im wrong here.
mga nagamit ko na oils na CI-4 rated ay:
Top1 Synthetic Diesel Oil = 260-300 pesos per liter
Zic Up semi-synthetic oil = 220-250 pesos per liter
parehong semi-synthetic yan. and both are good quality oils. antayin natin yung comments ng ibang gurus dito.
- Aug 2012
- 15
August 6th, 2012 07:01 PM #3thanks crazy_boy for the tip! ive heared na mahal nga ang turbo kpag nasira so it make sense din to use the right oil.
let see kung anong opinion ng ibang gurus dito.
thanks din for sharing the brand of oil and price na gamit mo.
base sa price range mas mura nga kesa kixx.
would you mind sharing kung san ka kumukuha ng top1or zic oil? thanks!
August 6th, 2012 07:07 PM #4
Ang pinapagamit ko ngayon sa mga medrep naming naka Accent & Getz CRDI yung Seaoil Deo Max 15w40 CI-4. OK naman ang performance niya. Kung gusto mong subukan nang isahan muna, nasa 160-180php/liter pero mas mura pa kung bulk. Kung kaya ng budget, bili ka rin ng mas magandang filter para ma-extend mo yung interval hanggang 8k km.
- Aug 2012
- 15
August 6th, 2012 08:23 PM #7Thanks po sir revenant!
mura nga yan seaoil deo max at api ci-4 pa ang rating.
synthetic po ba yan?
i think ok padin kahit hindi synthetic basta ang important is tama ang api rating at on time ang oil change?
san po kayo nakakakuha ng bulk order for your fleet? thanks!
- Nov 2011
- 538
August 6th, 2012 10:45 PM #9
- Nov 2011
- 538
