Results 1 to 9 of 9
    Sep 2016
    Hi Sir/Ma'am,
    Just to confirm po sa mga Grand Starex TCI 2017 user color green po ba yung Coolant na nakalagay sa unit natin? and ano po ba ang magandang brand?
    Thank you!
    Quote Originally Posted by ReggieMar View Post
    Hi Sir/Ma'am,
    Thank you!
    ilan na km travelled since last drain?
    if mababa pa, baka mas safer topup with distilled water.
    or flush then fill, pwede rin bumili sa casa para sure na same sa existing coolant mo.
    hth
    just checked my mom's gs. oem coolant is actually blue but manufacturers could change suppliers at anytime. if you are looking for green coolant readily available off the shelf brands are aisin mitasu. i'm not sure if peak or prestone has green coolant.
    Sep 2016
    hth
    27K na po ODO ko pero hindi pa sya na flflush, 1 year na po yung unit namin, salamat po sa inputs
    sa toyota long life kasi 100k miles yun initial, tapos after 50k miles per interval na.
    pero sakin 40k km initial, then every 20k km interval or every 2 years.
    Masyado yata maaga ka mag flush. Ling life naman yan pag brwnd new.
    Sep 2016
    hindi pa po ako nag flflush sir, medyo low level lang kasi yung reservoir ko below "L" level na kasi sya kaya I'm planning na topup na po muna.
    Masyado pa nga maaga mag flush ng coolant.
    May 2019
    Make sure that there's no internal or external leaks. Coolant level on the reservoir should stay the same.
Coolant question
