Page 33 of 34 FirstFirst ... 23293031323334 LastLast
Results 321 to 330 of 336
    Nov 2019
    #321
    It would have been better if comparison is done on a similar engine displacement size (2.0 Gas vs 2.0 CRDi). More liters of oil pa rin ba consumption ng 2.0 Diesel than the 2.0 Gas? I assume they should consume same amount of engine oil. And how about the additional cost of sparkplug replacement of gas engine?
    #322
    Quote Originally Posted by carxynogen View Post
    Take the case of Ford 2.2L or Mitsu 2.4L turbo Diesel engines, the difference in displacement against a 2.0L Mitsu gas engine is within 20%. The Diesel engines require around 6.5 to 7L while the gas engine only need 4.5L. So you need 2L more for the diesel.
    Our previous 2001 Accord 2.3L required 4.5L of oil while our newer 2016 Jetta 1.6L TDI also requires 4.5L. However, turbo gas cars require more oil than an NA gas engine. Our FXT which has a 2.0L turbo gas engine requires around 5.25 to 5.5L of oil. Even surprising was our previous 2014 Fiesta Ecoboost 1.0L which needs 4.5L of oil.
    Newer gas cars require longer periods of plugs replacement. Some do it around 60k km while some at 100k km. Unless of course, you suffered some kind of issue with your combustion settings that fouled your plugs earlier.
    Feb 2018
    #323
    Sparkplugs for mine (2.0) are recommended to be changed every 7 years or 168k kms. Tsaka di naman kamahalan yun hehe. Sa oil naman, 4.5L din so mga 2.5L difference.
    #324
    there was a time, when we cleaned and re-gapped our old sparking plugs, hanggang sa ma-ubos yung electrode, instead of replacing them as many do nowadays.
    probably because plugs were relatively more expensive back in the day, compared to now.
    Mar 2007
    #325
    Ganda pala ng sound system nito. Well as for me.
    Mar 2007
    #326
    Mahina ba talaga stock horn nito? Sino owners dito aside sa akin?
    Nov 2019
    #327
    Quote Originally Posted by suysuy View Post
    Parang mahina boss, hindi ko rin gusto yung tunog nya.
    Mar 2007
    #328
    Akala ko nga sira parang isang horn lang walang hi or low
    Jun 2012
    #329
    Mahina talaga busina ng koreans. Bastos kasi sakanila busina ng busina. Pero eon at i10 malakas. Kasi made in India
    #330
    Quote Originally Posted by dct View Post
    Mahina talaga busina ng koreans. Bastos kasi sakanila busina ng busina.k
    same with the japanese.
    horning is considered rude behavior.
    i intentionally disconnect one of my horns, to make it less noisy.
    horn driver kasi ako.
2019 Hyundai Sante Fe
